Is it safe to upgrade to Pulsar V3.01?
Acid Man
Post by Acid Man »
Any of you have experience with upgrading to 3.01? Currently I run 3.0 and this all works fine.
Is the V3.01 stable in combination with AMD and Win98SE?
Cheers,
Acid :eek:
JoeKa
Post by JoeKa »
I don´t think that there´ll be any problems related to the AMD CPU.
V3 had so many bugs on my system, I couldn´t work for about three weeks! But since the upgrade to 3.01 it´s working again, yahoo!
Well, not all of my problems have disappeared, but most of them, so I can continue my work.
Yet the only severe problem left on my system is an metallic crackling, stuttering ASIO24 source... but I guess I can fix this soon.
<font size=-1>[ This Message was edited by: JoeKa on 2001-11-06 08:19 ]</font>
Sam Mo
Post by Sam Mo »
I've done the 3.01 upgrade and it works fine on my system.
Well, 3.0 was also working fine :grin:
Acid Man
Post by Acid Man »
Ok then!
I will install 3.01 right away!
Thanks!
Acid :eek:
JoeKa
Post by JoeKa »
It was what I guessed: I record to my SCSI drive now instead of the IDE, and the problem´s gone! Stupid IDE-system! In my opinion SCSI should have become the usual standard long ago...
Well, I´m just about to rebuild my system as SCSI-only anyway so I´ll never see such problems again. But I will keep at least one of the IDE drives for backing up and maybe some games, too.
ide works fine for me as does scsi.dma checked?(i know you've been around and are sharp,but it should work fine.)
Acid Man
Post by Acid Man »
I recently solved a problem with my scsi hard drive. The D**n thing started up as a primary partition and settled on my E: drive (where all my progs are installed).
I downloaded PartitionMagic and changed the hard drive to logical and now everything works perfectly. Never have any problems with the scsi card though.
Finally I can do some serious audio recording (36GIG drive with 10.000 rpm). I already worked with this type of hard drive b4. You should check out: http://www.lacie.com.
Acid :eek:
JoeKa
Post by JoeKa »
Hm. Gary, what makes me wonder is the fact that before the installation of V3, the IDE drives worked commonly fine, up to 16 stereotracks never were a problem. And I have not changed anything since 2.04a...
The DMA-mode should be on, right?
It´s just a matter of recording, PB still does fine.
I´m going to find that problem with the IDE d´s... I think I already have a clue.
let us know...
JoeKa
Post by JoeKa »
Didn´t work out...grr.
Seems to be the V3 ASIO drivers eating up my CPU resources to the very end, so handling the data on the IDE drive is just that bit too much for it. SCSI doesn´t need CPU, so it works.
freddan
Post by freddan »
Has Creamware stopped sending out news updates via e-mail? I didn't get one for 3.0 or 3.01. Do you guys get mail from them?
/freddan
samplaire
Post by samplaire »
And it is for ages (macs have had scsi interface installed as standard for a long time and some of them had originally installed inner scsi drives).
Unfortunatelly you will see even worse problems - remember to have best cables available (it's not any cliche!), try to avoid disconnecting your scuzzy drives or do it not too often - scsi was my nightmare for a long time (ask anybody using scsi about it). FireWire seems to be THE solution (I haven't heard about any bugs, yet, but who knows?).
Sam Plaire
<font size=-1>[ This Message was edited by: samplaire on 2001-11-08 04:06 ]</font>
samplaire
Post by samplaire »
I'm a LUna + Pulsar user and got only news about the Luna 3.01 and no news about Pulsar updates, too
Air_PoLLo
Post by Air_PoLLo »
FireWire I think is 55Mbit/s wich should give 6.8 Mb/s.... I could be wrong.
Micha
Post by Micha »
From the FireWire FAQ at http://www.1394ta.org:
Does the 1394 bus compete with USB or Fiber Channel?
Almost everyone who works with these various buses considers 1394 a complement to USB, since it offers much higher speeds (up to 1.2 Gigabit :smile: ) and is designed for isochronous and asynch video/audio/data transfer. While USB is ideal for computer peripherals at speeds in the neighborhood of 12 Mbps, 1394 has a different mission. Many new PCs now include ports for both of these standards. Fiber Channel applications have been focused on disk drive and high-end storage, particularly data server applications.
Happy pulsaring
Micha
Air_PoLLo
Post by Air_PoLLo »
HEhe I said I could be wrong :smile:
