HELP ME AMD USERS!
fra.aie
Post by fra.aie »
hi all!
I just bought a Luna II, now i need to update mi computer, should i choose the new Amd cpu xp1500? The gygabyte motherboard has the amd 761 chipset (suggested by creamware)
What do you think about it?
Could i have problem with any sequencing software?
I need your help!
thank you.
<font size=-1>[ This Message was edited by: fra.aie on 2001-11-06 05:38 ]</font>
Use a setup that's on http://www.creamware.de or http://www.infinitevortex.com to compose your system. You won't regret.
yes thats good advice.i think the combo mentioned here should work tho.why not get the xp1.8? whatever you by will soon be slow, so why not get the fast one now so that you can wait a little longer to update in the future?
fra.aie
Post by fra.aie »
Thank you guys, finally some good advice!
Now, the new cpu XP serie is safe, isn't too young?
Shouldn't I wait a little bit to get the same cpu with no bug, more tested and sure?
Let me know!
thanx again.
vascomusic
Post by vascomusic »
How'bout a ECS (Elite Group) K7S5A motherboard & Athlon XP 1x00+ ?
It's a cheap, stable and lightning fast motherboard. The PCI bandwidth is also superior. Pulsar II/3.01 + Cubase 5 are running great on this configuration and can also handle extremely VST/DX-plugin loads with very low (ASIO) latency.
check out some reviews:
http://www.amdmb.com/article-display.php?ArticleID=112
http://www.legionhardware.com/Reviews/E ... 7S5A_1.php
http://www.ocworkbench.com/hardware/eli ... 7s5ap1.htm
Acid Man
Post by Acid Man »
What is this AMD XP 1x00+ about. I read the AMD site and as far as i can see the tray is especially designed for Windows XP. Or is it not?
Should I upgrade to this processor or is it safest to keep working with AMD 1400 Mhz. for now.
Funktastico
Post by Funktastico »
A processor designed especially for an operating system... j-sus this world is going upside-down. :razz:
Toni L.
http://www.mp3.com/NativeAlien
Funktastico
BTW. from what I hear, XP is safe, stable, produces less heat than TB, faster, and so on, so on... just make sure your memory doesn't become a bottleneck - if you go XP ditch SDRAM also and get DDR memory and a decent mobo.
Toni L.
Acid Man
Post by Acid Man »
Is it safe to use? I currently work fine with Win98SE and 768 MB DDR onboard. How long have you been working with XP? It never crashed?
Is it possible to install a stripped version of XP, or do you have to install the whole enchilada?
Acid :eek:
i think he meant the xp version of the athlon cpu.this is the latest generation. i'm sure it's happening as it's the third gen.
fra.aie
Post by fra.aie »
Is still somebody?
