Free Compressor Black Alpha corrected
Peter4724
Post by Peter4724 »
A big mistake.
The MIX Potti had no function.
This is the corrected version.
Hi
Another sounding Compressor. Placed two "Bands" on the side and middle signal.
Have fun
r
Peter
Black Alpha.PNG (187.2 KiB) Viewed 7583 times
Black Alpha_Corr.rar
(2.19 MiB) Downloaded 1145 times
Re: Free Compressor Black Alpha
Post by JoPo »
Fan-ta-s-ti-K !!
Yogimeister
Post by Yogimeister »
Thank you ! :)
ehasting
Post by ehasting »
Bang on! Great sounding compressor... and also very nice looking!
It really helps giving that "thump" sound to the bottom, and sound cool when driven hard!
Higen
http://www.higen.org
Yogimeister
Still exploring it ...
One thing though ... When i tweak the m/s to the left side (mono) i seem to be getting the output panned left ....
(Does this enable processing only on the left channel ?(??) )
Peter4724
Re: Free Compressor Black Alpha corrected
Post by Peter4724 »
Yogimeister wrote:Still exploring it ...
I can not find this problem but have another error noticed.
I corrected it.
ehasting
Post by ehasting »
Thanks regarding the mix pot.. not that i minded it when i used it, since i wanted all on.. but mix pot gives more options!
thanks.
Higen
Yogimeister
I corrected it.
Hehe thanx ... I didnt get to the stage of mixing it "out" yet ... Am still learning how to use it in 100% mix ;)
I will reDL and see if I can display the behavior I encountered .... ;)
But basically - what does the m/s knob do ?
(Feeds m or s into the "sidechain" ? Or m/s control of the signal (both in and out ?)
Peter4724
Post by Peter4724 »
Yogimeister wrote:But basically - what does the m/s knob do ?
The M / S mode knob turned to the left reduces the current threshold value from the side signal.
Right turned the threshold of the middle signal is reduced.
Yogimeister
Thank you :)
Does the compressor work on both bands seperately - or is there one single compression (attenuation) stage that will works on both bands (but reacts to a function of two different attenuation signal feeds? :)
(I couldnt understand if thats what you meant by two "bands" on m/s - or if u were referring to the bass band and the "else" band ;)
Peter4724
Post by Peter4724 »
Yogimeister wrote:Thank you :)
Here's the signal flow.
Signal input - high / low pass filter - 2-band frequency separation - M/S separation for each frequency band -
a compressor on the high and a compressor on the low for each M/S Signal.........out.
Yogimeister
Cool ... Thanks! :)
(If this is the case - may i suggest a seperate m/s control knob for high & low bands - to be able to tighten the mono image on low and expand the highs a bit ;)
