Freedevice VintageBTC
Peter4724
Post by Peter4724 »
The next days comes the rest
r
Peter
Vintage BTC_SC.PNG (208.89 KiB) Viewed 5240 times
VintageBTC.rar
(4.88 MiB) Downloaded 527 times
erminardi
Re: Freedevice VintageBTC
Post by erminardi »
:o
petal
Post by petal »
Peter4724 wrote:The next days comes the rest
r
Peter
Peter your contribution to the "free scope device"-section here on PlanetZ has been very impressive - Thank you very much for your kind contribution!
Clearly a lot of time has gone into developing them - Is there a story behind all these devices?
Cheers,
Thomas
and once again.........a greaat big thank you Peter......X3
petal wrote: Peter your contribution to the "free scope device"-section here on PlanetZ has been very impressive - Thank you very much for your kind contribution!
Cheers,
Thomas
I was asking myself the same. It's amazing.
If composing with atoms in SDK would be relatively easy (?) for an experienced develloper then there's still the magnifique GUI work.
A search on Peter's membership profile reveales this:
http://www.ist.at.
Look at the team menu, this is not to bad either...
Respect!
Ditykman
Post by Ditykman »
Wow
Great thanks merci gracias
Post by jksuperstar »
As usual, straight forward, intuitive to use, and does the work it is intended for. Thanks!
Works on XITE-1, with no issues for routing or insert.
Post by JoPo »
I just tested it.. It's a marvel ! As always, the GUI is nice but especialy the sound !
Thanks, Peter ! As Mr Arkadin said : you are spoiling us !
As usual, I need to know everything about the devices I like...
Could you tell us what are exactly the 'VT' and 'BC' knobs, Peter ? (I guess 'BC' is about the tube..?)
I congratulate you for all the devices you gave us !! Thanks thousands times !
Peter4724
Post by Peter4724 »
Hi
JoPo wrote: Could you tell us what are exactly the 'VT' and 'BC' knobs, Peter ? (I guess 'BC' is about the tube..?)
Vintage TC is a special sounding 3 Band compressor.
The tube preamp produces a lot of bass. The BC Slider is a special copmressor only for the bass after the tube. The VT Potti regulates the Tube drive (no MIX).
r
Peter
Post by JoPo »
Thanks for the info, Peter !
Now, I know all what I need and about the Softhancer too..
Believe me, your devices are on intensive use.
Yogimeister
Post by Yogimeister »
Thanks Peter - for the device and the explanation ...
(Would be great if you could bundle a few such notes (or tool tips) with your devices ... ;)
I was trying this one last night - but couldnt make 100% sense out of it ...
Is the "S"/bassfilter section a sidechain with solo option ? Or just a different band ?
