Freeware MBX5 Compressor
Peter4724
Post by Peter4724 »
Hi
I have found some.
Maybe not quite finished, but definitely useful.
r
Peter
Multimaster BX5.PNG (397.57 KiB) Viewed 11326 times
MBX5.rar
(1.74 MiB) Downloaded 771 times
erminardi
Re: Freeware MBX5 Compressor
Post by erminardi »
woah, thanks Peter!!! :o
Post by jksuperstar »
Damn, that's a really cool interface/implementation of the cross-over. It's immediately understandable and useable. It's almost perfect. And I personally *really* like having 5 bands...I'll have to put it to use, but it looks like an ideal replacement for the Spectral Balance Controller (SBC), which I always have loaded in my mixer for live jams & recording!
(I think the only improvement that could be made to the concept/gui is an FFT view where the cross over display is...which you more or less get from the meters anyways!)
A BIG Thank you!!
t_tangent
Post by t_tangent »
Yes, another great device, thanks Peter. Will check this out some more later on this evening :)
Post by JoPo »
Damn, Peter ! This is totaly ... I don't find any word..
There is not much other word to express a high enough ... mmm ... THANKS !
Nike Pogoda
Post by Nike Pogoda »
Very Cool !!
but... not work on XITE !
Help me please !
Peter4724
Post by Peter4724 »
Another person in which the MBX5 not work in Xite.
Om my XITE1 it works.
mausmuso
Post by mausmuso »
Thanks Peter,
Working fine here on XITE-1.
Edit: Works both as an insert and directly inline!
Love ya work!
regards
maus
Yogimeister
Post by Yogimeister »
Thank you ... I havent tried much of your devices yet - but they look great and seem very functional ... :)
Will check this one out soon :)
Post by JoPo »
It works perfectly, here on Xite-1, as insert in a multifx rack. Fantastic device.
t_tangent
Post by t_tangent »
yes working here on XITE-1 and PCI both in direct mode on routing window and as insert.
Thanks again Peter, a really nice compressor. :)
Nike Pogoda
Hello, Peter !
Im Sorry !
It was my mistake.
It works on my XITE1 too.
Great device!
Thanks!
Big respect !!
Post by JoPo »
MBX5 is excellent ! I'm trying to compare it with Optimaster ans I think I get better result with MBX5. Five bands are better than 3 ! :D
There is a damned limiter or brickwall limiter or whatever you call it, isn't it, Peter ?
Ditykman
Post by Ditykman »
Hello
This device is great great great very usefull
Thanks a lot Peter
Ditykman
https://soundcloud.com/ditykman/inties-dream
Post by JoPo »
From now on, I can't imagine life without this device.
Peter, It's huge.
Spielraum
Post by Spielraum »
yep, thats is :roll:
peter, i search for multiband with separately output per band -> Frequenzweiche
cheers!
m.my91
Post by m.my91 »
hello
is this plugins work a 96 khz?.
because many hpm plug don't work at this frequency.
(on a 15 dsp scope+pulsar2)
Post by JoPo »
Spielraum wrote:peter, i search for multiband with separately output per band -> Frequenzweiche
cheers!
Are you looking for a simple frequency splitter ? because there is several as free devices (such as FreqSplitter v0_2) or modular, if you are really looking for a multiband compressor with separate output, I don't know any... :D
But with those free devices, you could build it easily !
Always had an issue with the B2003 sounding like a real Hammond B3. It does do a great job of a stopped Rotor sound, then adding an Overdrive plug pre B2003 inputs for a close sounding ELP/Deep Purple tone, but the drawbars are just not Hammond sounding to my ears.
So I got Vb3 and a Melda MRotary Cabinet.
Tried using Scope Overdrive in between them by routing ASIO in puts and outputs back into Bidule, but ended up getting a Multiband Distrotion plug in from Melda and post VB3 pre MRotary and what a great sounding Hammond B3 I have now.
The above Multiband Compressor is excellent though in an Effects slot on the mixer for final touch ups, and I couldn't be happier.
Nice having the right bands and adding Limiting (high ratio Compressor settings) on every band.
Excellent news from the front lines in the War On Live Performance.........
If you need to tame a beast like an overdriven/distorted Hammond B3, and the percussion 3rd Harmonic is killing your tweeters, or the Bass is killing the woofer, or the midrange makes rocks fall out of your nose, this is the best Multiband Comp I have used.
Screenset capabilities would be the finishing touch for this gem.
ANkyu
