Having some issues with 3 cards to work properly
tlaskows
Post by tlaskows »
I am having some trouble with my 3 scopes. One is an SRB.
How many STDM cables should I be using?
When I use one, I can't max out the polyphony on synths and there's only so many I can load before it starts making a weird noise.
When I used 2 cables, I completely lost all synth output. May be a bad cable. I have enough connectors to make 5 cables, if required.
Thanks for your help,
-Tom
Re: Having some issues with 3 cards to work properly
there's no correct answer.
it depends on a number of factors including exactly what devices you use and in what order they are loaded. just try it and see.
tlaskows
Post by tlaskows »
garyb wrote:there's no correct answer.
Well, the problem is that with more than one cable, I get a horrible digital noise. I've tried up to 5 cables. I am gonna try shuffling the cards around on the motherboard.
-Tom
tlaskows
Post by tlaskows »
-Tom
Still getting bad digital clicks, several per second, with all 5 cables installed.
-Tom
i don't think that s/tdm cables cause this....but if 5 cables don't work, they don't work.
i suspect there's something else involved. have you cleaned contacts? are you certain you are connecting cards properly?
http://www.hitfoundry.com/issue_10/stm_mast.htm
tlaskows
Post by tlaskows »
garyb wrote:i don't think that s/tdm cables cause this....but if 5 cables don't work, they don't work.
Yeah, I followed that article to make my cables.
It worked fine with just a Pulsar II and 2 Scopes. Changing the Pulsar II to an SRB complicated things.
-Tom
maybe it's the srb itself...
tlaskows
Post by tlaskows »
garyb wrote:maybe it's the srb itself...
Could be. I'm gonna clean the contacts on it. I almost got it to work by switching cards around again...
-Tom
tlaskows
Post by tlaskows »
-Tom
Looks like there's a problem with the SRB. I am only running 2 cards now and they're working fine (5 connectors). Got two 16 poly Profits 5 loaded and works like a charm. I am gonna be returning the SRB.
Thanks for your help.
-Tom
too bad.
i'm glad you found the culprit.
tlaskows
Post by tlaskows »
garyb wrote:too bad.
Yeap, just confirmed it by running just 1 other card and an SRB. Same noises happens. I'm sending it back. The seller is cool with that. I just have to cover the shipping.
Thanks,
-Tom
