Someone knows how to solve this problem?
I installed the sync plate on my DAW and with 'win xp 32 bit' everything works perfectly.
With 'win7 32-bit', however when loading the module VCR128, VCR-S, Scope 5.1 stops working and displays a windows message ('ID events 1000'the module that generated the error is 'sim2k.dll');
when instead load Syncplate Dest on the project display a scope message: "TC02 unknow external symbol 'sav asta sync' this may be the result of an installation error or version conflict"
and Scope 5.1 stops working and closes.
I note that Ext.BNC and Ext.ADAT appear in the scope sample rate setting
I note that all cables are connected regularly to the sync plate and to Alesis Adat Recorders
I note that all the other modules and device hardware and software work perfectly.
Thanks for your attention.
Gigisound
VCR128,VCR-S,Syncplate Souce and Dest Modules Problem
Re: VCR128,VCR-S,Syncplate Souce and Dest Modules Problem
To use ADAT modules on scope 5.1 with win 7 you must run scope in 'Administrator mode'.
Sonic Core Luna II + Pulsar II scope v5.1.2709-x64, Cubase 9.0.20 (64), Pro Tools 12.7, Wavelab element 9 (64), windows 8.1 pro (64), Asus P6T 18Go RAM core i7 920, SSL Duende Native - Lexicon PCM Reverb Bundle - Waves - Sonnox
thanks for the tip but unfortunately it does not solve the problem
Gigisound
Gigisound
I enclose 3 photo error messages when loading modules "VCR128" and "Syncplate Dest" in the project Scope 5.1 (Win7 32 bit)
can someone help me?
Gigisound
Gigisound
- 01-Syncplate Dest.jpg (134.69 KiB) Viewed 3478 times
- 03-VCR128.jpg (223.35 KiB) Viewed 3478 times
- 02-Reg_Event.jpg (286.08 KiB) Viewed 3478 times
I can confirm that [ tco4: unknown external symbol 'SavAstatSync' ] too - Scope v 5.1 x64
well, this thing seems to be a constant source of surprisesgigisound wrote:Someone knows how to solve this problem?
I installed the sync plate on my DAW and with 'win xp 32 bit' everything works perfectly. ...
under WinXP in Scope 5.1 the VRC 128 used to crash on my system - similiar to your error message
now all of a sudden it works
at the time of those errors I once installed it under Win7, no problems... which also was confirmed by other users here
did you read the syncplate documentation ?
there are some restrictions on how to use those extra modules and which physical connections apply
