equinox/deep equinox clm example
this is a sound example of a phaser using bc modular modules in a clm shell
its based on a oakley sound hardware module
this is the first sound example
https://soundcloud.com/jhulk/jay
Re: equinox/deep equinox clm example
Sounds awesome.
sounds good. and happy to see jhulk back online!
Excellent !
Is the phaser module in Scope modular or in the Oakley modular synth ? I guess it's Oakley, if I'm right, what is the clm shell function ?
no its a circuit emulation using bcmodular modules built into a clm shell
then on the outside i have sliders for all the controls and a noise source and external source to a switch so you can switch between the 2
its a mono fx so for stereo you have to use 2 clm modules of the same circuit
the noise source can be used to set how you want the phaser to sound or you can use like jmj does as a extra sound source as noise phases well
Maybe, you have some pic to show us ..?
its being made into a bc modular module via sharc
so you will have to wait for the release of it
i made several phaser versions based on several analog circuit designs
i did the aries phaser/flanger which is 10 stage phaser and a delay flanger switchable
i did the arp quadra phaser based on late j haible design
i did the neutron phaser which is a 6 stage phaser with 2 modulation sources for wild phaser fx also a j haible design thats on the forum
and the equinox/deep equinox which is a 4 stage/8stage switchable
all will be released soon
- Bud Weiser
I´d wish someone could emulate a Mutron B-Phase, the old grey vintage MXR Flanger stompbox and/or the EH Deluxe Electric Mistress Flanger and the Bode Frequency Shifter which was better than the Oberheim Ring Modulator.jhulk wrote: i made several phaser versions based on several analog circuit designs
But a Oberheim/Maestro Ring Modulator would be cool too.
All these were my favourite FX always, as were Maestro Echoplex and later the Roland RE-501 tape chorus/echo/spring reverb.
But I´m looking forward all of your´s and Sharc´s releases and highly appreciate all your great work.
mutron is a 6/12 stage phaser it can be used as a dual input 6 stage phaser or a dual input 6stage with the first stage  output mixed with the secondstage input soi that it becomes a 12stage
it has dual lfo for wild fx the moog 12stage phaser is based on the same circuit
i have built the circuit but have yet to release it to sharc i will when i am back in the bristol studio in april when im due to mix down the vocal and finish the ep tracks
ill get the schematics for the others to see how they are wired and if i can create a module for them
i have noted down your list as i like these utility modules for modular as they are great for adding to the sound
inside the modular panel
sharc kindly uploaded screen shots of it for me as im away from my scope systems
http://www.bcmodular.co.uk/forum/viewto ... ?f=9&t=174
so jopo jump over and you can see how its created
Thanks a lot, Hulk !
It's done and downloaded ! And ready for the mutron !
not quite a dual input 6 stage phaser /12stage
but you will have to wait a couple of weeks for that version as its on my scope systems
- Bud Weiser
Hi !jhulk wrote:not quite a dual input 6 stage phaser /12stage
Great to read you´re interested in re-creating these FX devices for BC Modular.
I´m patient anyway ...
Please check your PMs for an uploaded assortment of schematics and service manuals including schematics.
best
Wow, this is really choice.
Thanks I will use 2 for Solaris
