I have permanent problem with shuffling\reshuffling plugins to avoid "sat connect error" in my projects (Win7 x64).
The worst situation is in XTC for sure - several plugins, a couple of synths -> SAT error (frequently unsolvable).
In normal mode - if I only dare to use Spacef Modular Mixer
Last lime I even got SAT error with 2448 (what is simplier?
If I include VDAT recorder in my project and get even once SAT error - it starts to record silence, not the project (and nothing helps further).
I've read here on PlanetZ a lot about some 'gold rules' to assign Mixers, I\O etc. manually to specific DSP, but when 'SAT errors' appear the best way I found to solve it - clear all assignment and let Scope make it automatically.
In fact, the question is:
What could I do to affect on 'SAT connect errors' (to make possible to use at least 60-80% of DSP usage)?
Is there any correlations with motherboard (I have Sabbertooth Z77, 1155), PCI-e slot selected (my xite is in PICex1 slot), I don't know, maybe CPU or RAM?
What is 'SAT connection'? Is there way to solve it by software and proper Scope updates or it is engineer' issue on XITE card associated with an insufficient number of paths between DSP chips and nothing can change it except to resolder XITE?
I remember the Garyb words about reshuffling as a feature, that others cards have not.
But with TC PowerCore, for example, I have at least a confidence that my amout of plugins used will work perfectly in projects every time I load it, despite on unoptimized DSP usage there. The same story with UAD.
