I have stumbled across a very annoying issue when setting up 2 x bcf and 1 x bcr to control scope mixers and effects.
I had assumed that if i set up a presets on each bcf with identical cc mappings but with each preset on seperate midi channels ( & to avoid cc conflicts between the bcf's themselves), that i would be able to use 2 of the bcf's to control 32 channels of the scope mixer (eg. preset 1 = scope mixer 1 - 8 on midi channel 2, preset 2 = scope mixer 9 - 16 on midi channel 3) etc etc.
I had hoped that having the mixer on midi omni would see it forward the fader feedback to the bcf's, but this only works if i actually set the mixer to the specific midi channel of the 'sending' bcf or bcr, and when i change presets i then have to change the midi channel on the mixer again.....ZZzzz
After a lot of googling and forum searching i have come to the conclusion that the only way to get the flexibility of using the bcf/r presets AND get the fader / led feedback back into the bcf/r's is to manually assign different cc messages to all of the encoders and faders of the bcf/r's & then run them all on one midi channel and assigning the same midi channel in the scope mixer.
I was wondering if anyone had had the same issue in the past and if they had already mapped all of the cc's for achieving either a 16 or 32 channel control set up OR if there is an easier way to achieve this....
If anyone has any useful sysex dumps already done for this, i would be very grateful if they would be shared
As usual I would appreciate any thoughts or wisdom anyone may have on this.
Many thanks,
Mark (auntybiotic)
