SoftSync and Modular
Roland Kuit
Post by Roland Kuit »
Here is a way to obtain softsync in your Modular:
RK Compared SoftSync.rar
(421.87 KiB) Downloaded 674 times
Roland Kuit Compared SoftSync.jpg (60.92 KiB) Viewed 23957 times
http://www.rolandkuit.com/
petal
Re: SoftSync and Modular
Post by petal »
I really enjoy these small modular excersices of yours. Thank you very much!
Please continue your good work ;)
jhulk
Post by jhulk »
i love these little doodles
hey roland stick them in a bcmodular clm shell then save it as a mdl
then you can re-use as a mdl every time
will save you lots of time as you can then use your doodles as blocks in a modular synth
jhulk
Post by jhulk »
like this one based on a phaser by the late j.haible
its called the neptune phaser
jh neptune phaser.zip
(1.36 MiB) Downloaded 605 times
jhulk
Post by jhulk »
to save as a mdl you delete the clm shell then it will give you the save save to new location then create a folder of yours in the modular mdls folder and save there
when you restart the the modular it will be in your folder and you can use the mdl just like any other mdl
you can do the same for your modular creations done inside the clm shell
then all your doodling is saved for use over and over again
Roland Kuit
That's a great way to "modulate" jhulk! :)
jhulk
Post by jhulk »
glad you like it
as you can see using the clm modular shell will make your life easy roland
wait to you see the orbitone
and the moog 914 module which i made fully modulatable
ehasting
Post by ehasting »
Higen
http://www.higen.org
