Hello
I'm not a profesional user but a make music
I have a question about reverb and how to do with it
I use reverb as bus in the stm 2448
i use short one for the room in bus 1 : rmx 160
and I use as long reverb the sc-plate
I mix on or/and the other as bus in chanels
It is the right way to use reverb
There is a better configuration (like sc_ambience for the short one for exemple)?
How do you use reverb and what kind in the scope environment?
Thanks for your answers
Ditykman
reverb use
Re: reverb use
as you know reverb and delay are typical 'send fx-', so use the AUX outs of the mixer to send them.
Get them back in over the Return channels of the mixer.
a long and a short reverb accessable from each audio channel through the AUX is perfect
Re: reverb use
Ok thank you
And what kind of reverb do you use in the scope environment?
rmx160 + sc plate it's good.
Thanks a lot
Thanks a lot
Re: reverb use
You have more choice than I have
I use two or three instances of Masterverb Pro.
A plate would be nice, to get different sounds.
