Z-Link On Xite-1
fraz
Z-Link On Xite-1
Post by fraz »
On the Xite-1 there are the Z-Link connectors that I use with Sonic Core A16 Ultra. As it is I can have 32 I/O with Xite-1 but I got lucky with this as I bought the older A16 Ultra that actually also had the Z-Link connection on. If I'd not bought this I'd only have the option of 16 I/O as the new Ferrofish A16 does not have the Z-Link connector on.
Are there any other ADAT boxes that have the Z-Link connector on? - Z-Link was Creamwares version of firewire wasn't it? -
Are Sonic Core planning on releasing another ADAT box with Z-Link on? - Someone could buy an Xite-1 or Xite-D and not be able to utilise the Z-Link ports on the Xite hardware if they can't find a used A16!
Re: Z-Link On Xite-1
The LUNA box.
fraz
Post by fraz »
dante wrote:The LUNA box.
Yes that's another way in....
there have been plans to make another Z-Link converter. i don't know if it will happen at this point. there may also be a MADI retrofit for the XITEs, but it's just a thought at the moment.
fraz
Post by fraz »
Ah how would that work?----Z-Link on Xite-1 to go into MADI on ADAT via a connector that S|C make?
no. madi instead of z-link.
don't get too worked up. it's not anything definite at this time.
Immanuel
Post by Immanuel »
As far as I remember, there is no support for the Luna converter from the Xite
auntybiotic
Post by auntybiotic »
+1 in hoping for a new Z-link compatible adat i/o
guppy
Post by guppy »
As the xite got a zlink port, it seems logical that sonic core should provide a way to connect some new a/d convertors which got zlink to it , or a way to connect adat/smux a/d convertors to zlink with a convertor :)
I think that if the a16 mk2 got zlink, a lot of xite users would think to buy one, even if madi is a good option, but not compatible with the xite without a conversion... Or add a madi/zlink convertor to buy.
It's a shame that we can't buy new a/d convertors with zlink at all for the xite, and must buy second hand A16 to do it :(
fraz
Post by fraz »
Yes Guppy - well spoken - :) - I'm only OK with this as I had a S|C A16 to use with Xite-1
How much would the cost be to implement the Z-Link on the A16 as well as the ADAT? - I know S|C is niche market but it could be made less niche and more mainstream with such development (this costs £££$$$EEE) to set up - :-? but hopefully with Scope 6 more of the niche is overcome so more people become Scopers..... :)
