Multiple keyfiles : how does it work ?
Shamk
Post by Shamk »
Hi all,
I always used only 1 keyfile because until now i did'nt have the need to use more, but if i have one main card with scope 5.1, and others with scope 4.5 plugins from another card (present on the setup), can i enable these plugins with scope 5.1 by asking sonic core to generate new .v5 keyfile ?
Regards
Creamware Scope 5.1 (Scope Power Pulsar 1.01|3 x Pulsar II|Pulsar I|Syncplate), scope abuser since 2004.
Asus Z87-K C2|Intel Haswell Core i7-4770|Kingston KHX1600C9D3K2/8GX - 2 x 4 Gb Ram (1600 MHz)
13 MV @ Masterverb Test
Re: Multiple keyfiles : how does it work ?
yes, you would need to write into support requesting v5 keys for any plugins that need them. you need to attach the old keyfiles and your current v5 keyfile.
only the upgraded card will have the v5.1 software key still, but all cards will work if they're in the same machine and the extra plugins will work for all cards as long as the card that has the key is in the machine.
