I have been using this motherboard with success, I just thought I would hand this on.
http://www.asus.com/Motherboards/M5A87
3x PCI slots running 3 scope cards, AM3+ socket with a AMD FX-8350 (8 Core) CPU
For me this motherboard has been a great option !
						M5A87
- vascomusic
Re: M5A87
Thanks for sharing this info!
Are you running 3 DSP boards on this mainboard?
I wonder how many Masterverbs the chipset is able to handle..
Re: M5A87
This chipset carries a heavy DSP  load, i have not done the reverb test. I have had a  problem with little dropouts in asio audio. so I am unsure what is causing this, it could be the chipset.. Or it could be problems with the driver and cubase 7.5 and ASIO GUARD.. I am running 2xpulsar2 1X luna 2 cards.
						- vascomusic
Re: M5A87
Thanks for your reply.
Dropouts can be caused by many things.
Some tips:
In BIOS setup try:
PCI latency timer 64 or 96
Disable HT (Hyperthreading)
Disable (CPU) stepping settings
Disable power management.
Disable onboard devices not needed.
In Windows:
Disable video bus-master option if possible (depends on brand/driver)
Try to increase the ASIO buffer size / increase latency in Cubase (I don't know if possible with Cubase 7.x)
Try raising ULLI latency ms in SCOPE settings, and try other types of ASIO (dest) module in SCOPE.
If Windows 7 or 8:
try DPC Latency Checker for detecting possible bad drivers http://www.thesycon.de/deu/latency_check.shtml
Some tips:
In BIOS setup try:
In Windows:
If Windows 7 or 8:
