Freedevice Extreme CUT
Peter4724
Post by Peter4724 »
Hi
I hope, your had some relaxed days.
High- and Low Cut devices.....
Not really new however a "must" in each channel.
r
Peter
Extreme CUT.PNG (108.52 KiB) Viewed 4272 times
extreme CUT.rar
(632.48 KiB) Downloaded 380 times
t_tangent
Re: Freedevice Extreme CUT
Post by t_tangent »
Thanks yet again Peter. Yes having a great holiday here, and just keeps getting better :)
Thanks for the Mono and Stereo versions.. :wink:
The LFP seems to work more like a HPF, but has a nice reach over shape, and frequency.
The HPF has a less pronounced effect over the audio.
But these are early tests where I ran in a channel as inserts, placing the LPF first as it's shape indicated mild to extreme peaks from left to right.
Then the inverted shapes of the HPF I assumed could be used in a linear fashion which would boost Low Content by taking away high frequency content.
The effect wasn't as noticable as I would have expected for a 40db cut.
So bypassed it then used the LFP only and it actually seems to cut the LPFs more, it sounds nice and transparent, but maybe I have their needs/uses backwards or something.
I will try them in a parallel fashion, insted of the serial fashion of a Channel Strip....
faxinadu
Post by faxinadu »
thanks!
http://www.oceanswift.net
Music
ehasting
Post by ehasting »
Higen
http://www.higen.org
