problem custom preset file
heiwa_boken
Post by heiwa_boken »
hello
when I load my custom preset file in the profit5 or pro wave. it does not load.
my version scope 5
I uninstall and reinstall but no work.
before it functioned very well.
Re: problem custom preset file
the file has the extension '.pre'?
sometimes I end up with a project file without the .pro part.
Won't load, but adding 'pro' is all I have to do.
The file is there, in the right preset folder?
heiwa_boken
yes the file is "pre"
djmicron
Post by djmicron »
can you share a non working preset file here?
So that we can see if the problem is on the preset file.
heiwa_boken
hello & thank you
Here are the file .
load Preset.zip
Here are the file
(132.33 KiB) Downloaded 137 times
djmicron
Post by djmicron »
hi heiwa_boken,
i loaded your preset files for the profit5 and it contains the default banks(factory, jesse, marco paris, midi controller), so it loads without problems here.
I have added another test bank called micron, so if you wanna try it, it should load the default banks and an additional micron bank.
Also tried the prowave and it is ok too.
micron.zip
(53.71 KiB) Downloaded 152 times
heiwa_boken
hello & Thank you very much
your file is work.
sorry i'm noob.
sorry the error comes from me, I usually to loading the project (.pro) and it's instant.
but with the preset , It is necessary to make that : bank - create /preset - Store / file - save as .
thank you to you all .............
Preset handling on Scope is clumsy (as with file management), so don't blame yourself too much :)
