Faxi Nadu - Four Corners Mod Pack (over 100 patches inside!)
Faxi Nadu - Four Corners Modular Pack
Download:
http://postunder.net/files/faxi_nadu_-_ ... d_pack.zip
Release: December 2013
This is a collection of patches for Sonic Core's (Creamware) DSP Modular system.
Some of these are useful utilities while others are more elaborate and interesting synthesis tools.
These patches are shareware, feel free to use them any way you see fit in your creations and modify them any way you wish. All patches by Yaron Eshkar aka Faxi Nadu. If you find these useful, spread the word about Faxi Nadu music,
Requirenments:
- At the very least a 6dsp system to access most patches. Prefarbly at least a 12 dsp system to really have fun. Many of the patches are monophonic in concept, but for polyphonic work, you will need LOTS of dsp as some patches are very heavy even in monophonic mode. As a general rule, the bigger the file size the more dsp the patch will likely consume when loaded.
- For All patches:
- Modular 4
- Adern Flexor V3
Install:
- Copy the whole folder to your modular devices folder
Shouts to everyone who is keeping SFP alive!
Download:
Download:
Requirenments:
- For All patches:
- Modular 4
- Adern Flexor V3
Install:
Download:
http://www.oceanswift.net
Music
Music
Re: Faxi Nadu - Four Corners Mod Pack (over 100 patches insi
100% freeware, but if you wanna show the love, there is the ocean star empire debut album and/or my new samplepack that would love your support
http://www.oceanstarempire.com
http://faxinadu.blogspot.co.il/2013/10/ ... epack.html
cheers!
cheers!
Music
Music
Thanks Faxi.
Reverse Engineering with you and Roland K is always such a learning experience and treat as well.
Cheerz.
Cheerz.
The Modular Inserts are great, many nifty ideas.
The Sequenced Glitch Machine is especially amazing.
Now I understand what Glitch is all about.
Great work.
Took a lifetime to dl. using IDM, but when transferring from USB 3.0 stick to DAW
it was like greased lightning.
Ankyu
Great work.
Ankyu
- Roland Kuit
Thanks Faxi!
I will have a go on this in Sweden!
http://www.rolandkuit.com/
cheers amigos, yeah the glitch one is probably the most interesting concept on this pack.
the idea was:
Sequenced FX Glitch Machine
Incoming audio is fed into 8 separate channels each consisting of a different effect with its own envelope and vca, where the vca is controlled by a gate sequencer, so that a channel will trigger only on a 1/16 hit that has a gate signal. Then all the channels are added and the summed output is played. Instant madness, crazy fx rhythm out of pads and glitch galore
this is kind of a scope representation of the vst dbglitch, but here was have the whole array of scope fx at our disposal
the idea was:
Music
Music
this one is pretty neat too i think:
The Gates of the Table
There are 8 wavetable oscs. With each new midi note the switch advances one step thus playing the output of the next osc.
Music
Music
heehe really i don't think i am anywhere near roland's level i must saydawman wrote:Thanks Faxi.
Cheerz.
Music
Music
Well I benefit from all of the awesome ideas others create, then it's my gig to add musicality and learn from reverse engineering on the same token.
Ankyu
Ankyu
honoreddawman wrote:Well I benefit from all of the awesome ideas others create, then it's my gig to add musicality and learn from reverse engineering on the same token.
Ankyu
Music
Music
Gates of Table is awesome. I shall make a slimmer version for the sake of polyphony as this can't be done on Solaris, hence a need for such diversity.
Ankyu
Ankyu
soren_jepsen
Hmmm, the domain is down. Is there anywhere to get a hold of this pack?
Cheers
Søren
Cheers
Søren
Yogimeister
Music
Music
