I remember some people tried, but i don't remember the issue ...
4 Pulsar Scope in a same system ?
I did'n find any old topic about that ...
Creamware Scope 5.1 (Scope Power Pulsar 1.01|3 x Pulsar II|Pulsar I|Syncplate), scope abuser since 2004.
Asus Z87-K C2|Intel Haswell Core i7-4770|Kingston KHX1600C9D3K2/8GX - 2 x 4 Gb Ram (1600 MHz)
13 MV @ Masterverb Test
Re: 4 Pulsar Scope in a same system ?
I think the issue is the PCI overload.
But if the main goal is adding more inputs without flooding the whole PCI bus by some MV, i hope this could be done !
Experiments have been made without good results on that. At least that I'm aware of.Shamk wrote:But if the main goal is adding more inputs without flooding the whole PCI bus by some MV, i hope this could be done !
i'm running 2x 6DSP Pulsar II Project Cards on my new system.
based on the "Masterverb Test" the PCI caps 2 MV's before the DSP. 13/15.
I tend to do more signal routing than sound generation/fx so I haven't seen any problems on that front, but 4 might be a different story.
good luck!
good luck!
Apparently may run but ...PCI Overload limit...
