windows 8.1 upgrade
maggiau
windows 8.1 upgrade
Post by maggiau »
hello, I tried to upgrade to windows 8.1 from 8 ....
and came back to 8.0 ...
anybody was able to do it ?
thank you
Re: windows 8.1 upgrade
Ive got 8.1 running on my non-DAW laptop ok.
Ripper
Post by Ripper »
I had no problems with it.
maggiau
Post by maggiau »
with scope drivers without doing anything ?
you need to reinstall the drivers. just rerun the installer.
Ripper
Post by Ripper »
maggiau wrote:with scope drivers without doing anything ?
Just re-install them the way you did in 8.0.
maggiau
Post by maggiau »
ok thank you, I will try this week-end :-)
dest4b
Post by dest4b »
oh no !!!
my scope DAW worked better then ever..
with Win8 64bit, sfp 5.1 and ableton .
and i did it .. i installed the 8.1 update .. now my scopes don't want their drivers.
If i run the sfp setup as admin i get:
Found "Sonic Core Pulsar2"
ERROR: InstallDriver returned -2
windows8 requires you to turn off driver signing when installing. you had to do this to install the driver in win8 the first time.
my usual cut-n-paste:
windows 8 requires the driver to be signed by microsoft. the Scope driver isn't signed so you must turn off the "feature" that requires this. here are two easy methods to install the driver. i prefer the second one in the link.
You can permanently enable Test Mode by opening an Elevated Command Prompt and typing the following commands, then rebooting:
bcdedit -set loadoptions DISABLE_INTEGRITY_CHECKS
bcdedit -set TESTSIGNING ON
hit enter after each command. to open an elevated command prompt, use these instructions:
http://pcsupport.about.com/od/windows-8 ... dows-8.htm
To turn it off again, use these commands:
bcdedit -set loadoptions ENABLE_INTEGRITY_CHECKS
bcdedit -set TESTSIGNING OFF
here is a second way to enter test mode:
http://www.fotoclubinc.com/blog/how-to- ... windows-8/
dest4b
Post by dest4b »
ohh .. i remember something like that .. this should be sticky or added in soniccore FAQ..
i really searched before asking here ..
great help & pasting !!
Thanx garry :)
its rocking again!
it's a windows thing...
