DSP Limit test on the XITE-1
djmicron
Post by djmicron »
Testing with optimized devices and some manual assignments to fill every empty space on dsp's.
Re: DSP Limit test on the XITE-1
djmicron wrote:Testing with optimized devices and some manual assignments to fill every empty space on dsp's.
Wow !
Have you optimized Inferno too or is it stock device ?
LOL! That is both impressive and hilarious at the same time.
I've adopted a line from the movie Aladdin to describe the Xite-1
"Phenonmenal Cosmic Powers, Itty bitty living space"
djmicron
Post by djmicron »
Wow !
i'm converting all the synthesizers, but in this example inferno has been assigned manually to dsp's from 1 to 18.
This is great progress as I have never been able to get above 65% using Modular assignments and Assigned/Cleared Devices.
Look forward to more uncorked secrets to emerge.
Maxed out close to 90% here on the 'D' - somewhat easier to max out than full XITE but still tricky enough :
http://www.xited.org/viewtopic.php?f=18&t=1054&start=0
djmicron
Post by djmicron »
dante wrote:Maxed out close to 90% here on the 'D' - somewhat easier to max out than full XITE but still tricky enough :
I'll upload the devices that loads on dsp's 7 to 10 for the D, it's really not tricky when the device is loaded straight on the specified dsp and you can also use the dsp's 1 to 6 for lighter devices.
