Solaris on XIte - 12 voices poly test
Planet Z Announcements
djmicron
Post by djmicron »
I'm working on it, look at this demo video:
http://youtu.be/Ds6eU1k9KUc
12 instances of solaris, each one on it's own dsp from dsp 7 to 18, running a patch that reaches around 50% per dsp.
Polyphony managed by midi(working on a device to do that).
Thank you
Sal
Re: Solaris on XIte - 12 voices poly test
Post by jksuperstar »
Yes! Thanks for getting a jump start on this way to work with polyphony!!!
And for the great work you've been doing.
Awesome can't wait! Thanks for working on this.
shayart
Post by shayart »
Great that you are working on it....... :) :) :)
It would be a dream ...For all of the zarg synthesizers!!! :wink:
djmicron wrote:I'm working on it, look at this demo video:
Awesome !!!
djmicron wrote: 12 instances of solaris, each one on it's own dsp from dsp 7 to 18, running a patch that reaches around 50% per dsp.
That looks impressing.
I have no idea how you manage to tweak the devices that way, but please allow one question:
Would it be possible, in theory, to run more voices on 1 chip and using less instances, so we´d have some more chips free for other devices in addition, or is it not advisable because there might be patches using more DSP tham 50% per chip and voice ?
The background is, the hardware Solaris is an expensive boutique machine and it´s a bit different than the software Solaris.
Now when Solaris runs w/ 10 voices (or more) on XITE-1 and we´d have the option to run a bit more stuff in addition (maybe modules in Modular ?), it would be ice on the cake,- now since hardware Solaris costs as much as XITE-1 costs.
djmicron wrote: Polyphony managed by midi(working on a device to do that).
You do unbelievable work,- thx a lot !
In my experiments, it does seem like at least 1 solaris will fit per dsp. Certainly some uses will allow for more than 1 per dsp, but since there are so many modules for oscillators and filters that can be loaded, each use may vary.
Placing a mixer for all the voices to minimize phase/latency is another task. A dynamic mixer could be cool, that changes with a max-voice setting via a script.
djmicron
Post by djmicron »
Would it be possible, in theory, to run more voices on 1 chip and using less instances, so we´d have some more chips free for other devices in addition, or is it not advisable because there might be patches using more DSP than 50% per chip and voice ?
It depends on the patch, but 2 voices per dsp is possible if we take care.
That would be cool !
Hardware Solaris works similar,- 5 chips do the 10 voices (2 per chip fixed for the time being) and the 6th chip does the rest (FX & routing etc.).
good luck and all the best
I like the way Sal shares this with us and then says thank you........ :lol:
Good Work.
Post by JoPo »
Djmicron, how do you do this ?
(sorry if I missed something...)
Do you have some kind of sdk ?
I already tried your dsp optimized files, really helpful with the Xite dsp gas factory... Are we going to take advantage of the Solaris ones ?
djmicron
Post by djmicron »
JoPo wrote:Djmicron, how do you do this ?
this is done with the sdk 5, i'm developing a midi voice allocation module to manage multiple solaris(and every other synth) as one poly synth.
