delays and reverbs no longer working after upgrade.. help?
faxinadu
Post by faxinadu »
hello,
since installing v5.1 scope and sdks 5 and 6 suddenly in scope some plugins do not respond anymore. they do load, but they just don't do anything and send the signal dry. namely this happens with the delays and reverbs. any idea?
thanks
http://www.oceanswift.net
Music
Re: delays and reverbs no longer working after upgrade.. hel
admin mode?
rerun the Scope v5.1 installer.
faxinadu
Post by faxinadu »
im on windows xp machine, should not be affected by admin mode no? will try anyhow, also will try re-install.
Music
no, no admin mode in xp.
faxinadu
Post by faxinadu »
so what it was is the "newer" sdk drivers, once i manually uninstalled the drivers and re-installed the scope5.1 drivers and also the application things work.
maybe worth looking into.
Music
the SDK6 driver is the same as v5.1 afaik, at least it was....
