32 channels of ADAT into Scope 4.5/5.1 using Pulsar 1 or 2
quantum
Post by quantum »
Is there a way to connect 32 ADAT channels into Scope 4.5 or 5.1 without using any format converters? What's sad is that there's only one format converter out there, Mutec, and only accepts 16 ADAT channels. The other one is Z Systems 8.8A and M-Audio SAM, which I cannot find anywhere to buy.
As of now, I would have to get two 16CH ADs and two Mutec Format Converters, and then mix them digitally through Roland M1000, which I already have.
Re: 32 channels of ADAT into Scope 4.5/5.1 using Pulsar 1 or
format convertor?
you just need two 16 channel AD/DAs with ADAT and two cards, or four 8 channel AD/DAs with ADAT and two cards....
quantum
Post by quantum »
Great. I am assuming they should show up as ADAT A,B,C, D in Live Bar if using both cards in ADAT mode. But will I still have coaxial in and out on both cards or just one or neither while in ADAT mode?
all possible i/o connections are always available.
