A16 ADAT/Wordclock Issue
grappa
Post by grappa »
Hi all,
Gone to fire up the gear today and have a bit of an issue.
XITE-1 plus 2 x A16u one via ZLINK and one via lightpipe. XITE-1 is wordclock master and Z-Link connected A16 is fine and sync'd. ADAT connected A16u unit is showing no wordclock sync on the front and pulling the lightpipe cables there is no light outpit on outputs A & B on the A16u? It's as if the ADAT module in the A16 has failed?
Any ideas? Are these serviceable or is it a second hand or Ferrofish unit?
Appreciate any help you can give.
Regards,
Simon
Re: A16 ADAT/Wordclock Issue
Ferrofish can and will service your old A16.
when you say "wordclock" are you talking about BNC clock, or just the clock signal that is transmitted via the ADAT and Z-Link connections?
