need midi output selector
I am currently using a Kenton Control Freak with my Luna II card. I've found that I have to switch between different midi outs and sequencer midi ins quite a lot to access parameters on other software and external gear. This process could be steamlined by the introduction of a midi controlled midi output switcher device. For instance you plug the Luna midi in port to the switcher device input. You then have 4 or 5 outputs which can be routed to the midi outs / devices of your choice & you switch between them via midi controller messages. Who knows maybe it's already out there and I've missed it or I've overlooked a workaround. Can anyone help?
