Odessa
soren_jepsen
Odessa
Post by soren_jepsen »
This is my first device using the SDK. There's probably some kinks and wrinkles to be addressed, so please leave a comment if you find something :-)
It's really not anything new, as it's based heavily on the Arp Odyssey. Also, I have no access to atoms in SDK 5.1, so I had to make do with what was available as modules.
Sharc has been very helpfull, and made a sample&hold module for me. Hats off!
Anyway, have at it and please leave comments and ideas (I already have a few). It should work all the way back to Scope 4.0. I had it running on a Luna II card with 3 voices.
Regards
Søren
Odessa 1.JPG (81.51 KiB) Viewed 8903 times
Odessa 1.zip
(243.58 KiB) Downloaded 587 times
Re: Odessa
looks great. can't wait to try it. thanks
Re: Odessa
Excellent sounds and great presets.
I am automating it now using Modular LFO to MIDI patches by brotha' man at0m.
The way I can store Voices per preset is appreciated as this is a great little mono/poly synth.
I'd love to see some Traingle LFOs to use with the PWM for that semi-rough edge.
Awesome Gift
Ankyu
Roland Kuit
Re: Odessa
Post by Roland Kuit »
Thanks, I will look at it tomorrow.
http://www.rolandkuit.com/
soren_jepsen
Re: Odessa
Forgot to mention:
I made a layout for iPad app "TB MIDI Stuff", so you can sit at the keyboard with your iPad and program the synth. I've attached the file, in case any of you folks use that app. On that note, I can't wait till SDK6 gets to a usable point, so we can start implementing OSC :-)
The layout (or page as I think it's called) is not comprehensive, but most things are there. Anyway you can easily edit/add in the app (one of the things I really like about it).
Also the synth (and this page) follows the the way cc-messages are set up for the Prodyssey. So you could program the synth from the hardware Prodyssey (not sure that would make sense thou :-))
The page is attached.
Odyssey.zip
(111.94 KiB) Downloaded 415 times
Shroomz~>
Re: Odessa
Post by Shroomz~> »
Very cool, thanks! Will check this out later tonight.
ShogunSpy
Re: Odessa
Post by ShogunSpy »
Thanks !! Was taking a little break from the studio and now you have tempted me! :wink: Will try it out this evening ..Great to see new devices role on scope 6 !
Roland Kuit
Re: Odessa
Duophonic as I understand?
Some nice sounds.
soren_jepsen
Re: Odessa
You can change the number og voices, by clicking on the number and drag up or down. I get three voices on a Luna2 card. I havent tested max numbers on the XITE :-)
Roland Kuit
Re: Odessa
I see. I used to play an ARP2600 duo phonic.
Just tested it, at least 12 voices in a basic Scope template.(Which you can make cheaper in DSP usage).
12 voices.jpg (30.58 KiB) Viewed 8697 times
Re: Odessa
I got 5800 as a value in the XITE-1 DSP usage with 7 Voices as I prefer staying on a single DSP chip.
But I can get many more voices as it spans across the DSPs.
It seems well optimized and it sounds nice plus it's a different kind of beast.
Adds diversity to the collection.
Thanks Again
53E7
Re: Odessa
Post by 53E7 »
Thank you for this great synth! I like the ARP style. Nice job on the presets too (love the synth strings preset). I wish the MIDI channel and polyphony didn't change back to the default settings every time I switched a preset. I look forward to your future work.
soren_jepsen
Re: Odessa
Thanks for the nice comments :-)
53E7 - you should be able to save the presets with the changes you make. Voices and midi channel are saved with the presets.
Regards
Søren
53E7
Re: Odessa
Post by 53E7 »
I did notice that. Just for future projects, it is nice to scroll through presets while a sequence is running to audition presets, so keeping the MIDI channel and poly the same nice to have (and most Scope synths do have that ability).
ehasting
Re: Odessa
Post by ehasting »
added to http://www.scopeportal.com/soren-jepsen-odessa/
if anyone wants to add devices - PM me for username and password (not sure if i have mention it before :P)
All developers ... be clever - add it to the scopeportal when you are posting it to the forum! :)
Higen
http://www.higen.org
