SDK6
Roland Kuit
SDK6
Post by Roland Kuit »
When patching stuff I want to delete/change a module. By deleting not all, but some of them, SDK6 stops working.
How come?
http://www.rolandkuit.com/
Shroomz~>
Re: SDK6
Post by Shroomz~> »
It's not a known issue in SDK 4 or 5 Roland, so not being an SDK 6 user, I can't help.
Re: SDK6
you might want to let Julian know, although i haven't heard of such a bug.
do you have an irq shared with a USB controller and the XITE?
Roland Kuit
Re: SDK6
Thanks Gary,
I looked at the IRQ's, but no conflicts.
I have this problem on both my laptops.
Re: SDK6
it's when you select several modules and delete them together, right?
if you delete them all one at s time it's ok?
Roland Kuit
Re: SDK6
No, just by deleting one module. And it depends by which module I'm deleting.
F.i. I was creating a Glitch Delay. So I needed the Analogue In and the output to the headphones.
Deleting the Analogue In causes(every time) stopping the SDK6 software.
I get a windows failure: DEP problem, but I can't change that.
Sometimes I have to start up Windows again after this failure.
Roland Kuit Glitch Delay.jpg (133.56 KiB) Viewed 8660 times
petal
Re: SDK6
Post by petal »
I didn't know that the SDK6 was available yet. I believe I paid for it when I bought my XITE a year back. How did you get your hands on it?
Roland Kuit
Re: SDK6
I got my Xite-1, Mod IV and SDK6 in February this year by mail.
petal
Re: SDK6
Post by petal »
Hmm. Sounds like I need to write a mail.
Thanks for the insight :)
Re: SDK6
ok, i'll write a letter to Julian.
Re: SDK6
if you're getting DEP errors, perhaps an elevated level of security is set in windows. DEP is windows security. i think there's settings in system properties\advanced\data execution protection. the first box should be checked, "turn on DEP for essential windows programs and serices only".
also, the SDK needs to run "as administrator" too...
Roland Kuit
Re: SDK6
The last trick did the job. Run as Admin.
Thanks Gary!
wouterz
Re: SDK6
Post by wouterz »
I have a similar problem (on windows XP) when I delete a module sometimes the SDK application crashes (Error message: "Pure function call"). Run as admin does not help.
djmicron
Re: SDK6
Post by djmicron »
i use the sdk 6 for exporting dsp modules only.
I too can't delete modules and can't develop GUI, it is still in beta and we need to wait for updates.
jhulk
Re: SDK6
Post by jhulk »
you need to ask for the gui tools
as it was missing from the sdk6
for the guitools you need the juce and on pc the visualstudio2010c++ ide and then make a introjucer so that juce can
be used to create gui and the scopedll.lib which you can then create a dll file to put in the scope sdk6 or 5
this way you can create native fx models that interfaces with the sdk6 via the dll which has async i/o control and sync i/o audio
which the sampler modules use
you need to ask garyb for the guitools because with out it you cant make gui
another program to get is knobman for png nobs and switches so you can create your own
there are other vsti gui tools also but the juce is a good set the wusicstation and there new modular plug uses juce
Re: SDK6
Post by jksuperstar »
Make sure you build your Juice GUI with multi-touch enabled. Might not be a big deal right now, but it will be someday ;). futureproof!
Eanna
Re: SDK6
Post by Eanna »
wouterz wrote:(Error message: "Pure function call")
Pure Virtual Function Call...? Don't remind me ;-)
jhulk
Re: SDK6
Post by jhulk »
thats just a matter of adding osc control
jhulk
Re: SDK6
Post by jhulk »
djmicron
Re: SDK6
Post by djmicron »
jhulk wrote:you need to ask for the gui tools
i did ask for the gui tools, not possible at the moment.
You don't need juce or vstgui, you can develop your code how you prefer, juce is just a way to do it, but i'm talking about something written in the sdk6 manual that i can't test at the moment.
