Can't install Pulsar, problem with reg Key
Symetrix
Post by Symetrix »
Hi all! Maybe someone could help me...
I'm installing Pulsar sofrware for 1st time (the driver is already installed),
and I got the following problem
I have a text file (with extention *.rgy) with keys for Creamware software, including the key for Pulsar,
but whet I try to put in to the correspondent field of my installation, the is mismatch - the is
much more symbols in my key, than I can maximum put to the field "Pulsar key"
Could someone please tell me, what I'm doing wrong? :(
Re: Can't install Pulsar, problem with reg Key
put the keyfile on your desktop and then use the browse function to choose and import all the keys into the registration window.
Symetrix
Post by Symetrix »
Thanks, but I don't see any browse function or "browse" button.
I have just NEXT, BACK and CANCEL... :o
petal
Post by petal »
You are given an option to import a key-file during installation. This is where you use the "browse" fucktion Gary is reffering to :)
Symetrix
Post by Symetrix »
...i was trying to start setup once again from the beginning, and I still don't see such option...
petal
Post by petal »
ok - try to put your rgy-file into the installation-directory under app/bin/
it should be named scope.rgy
what version of Scope are you installing?
pm a copy of your keyfile to me.
