I have a problem with Scope autostart when loading Windows 7 (64bit)...
for years I always ignored it and always used to manually start Scope 5.1 just when I needed to use it, leaving the option unchecked in the autorun applications,
because I was using the onboard audiocard as default Windows audiocard.
But now I want to use Scope as main default soundcard and have it autorun and hide/reduce automatically at Windows start.
the problem is that I don't find anymore the option to check again and activate the autostart!
Please, do you know how to have it again?
I tried to reinstall Scope 5.1... (also uninstall and reinstall again), but it didn't fix
the autostart of Scope.
Only lost time for now.
Can someone help with this?
Thanks in advance.
All the best.
