Env with slope attack
Post by JoPo »
Hi...
I'm looking for an enveloppe which has a exponential slope attack but all I can find is a fast attack which slows down and none with slow attack wich speeds up.
I guess it is makable but I need some help.... :D
Thanks !
Re: Env with slope attack
Post by JoPo »
Well..
I meant an attack like on the jpg...
Slope attack.png (2.04 KiB) Viewed 6327 times
Post by JoPo »
Ok.............
Done with the simple curve table... :D
The only problem is that it affects the decay & release too.
Signed the eternal mod beginer.
maybe you can add what you want by 2 envelopes one after the other ?
the first one with slope 'extension' on attack, the rest as zero
second one with attack zero and the other values set to what the first envelope had originally
I have no idea if that is workable at all, but it showed up before the inner ear... :D
(now with Flexor III)
Post by JoPo »
Yes, interesting idea.
I'm trying to decompose the attack on one side and the decay & release on the other. I would need a module wich outputs signal only when it increases or decreases. I don't find any.
My idea is to recompose the signal after.
yeah, it's an interesting idea... but complete rubbish (what I wrote above)
I'd better have had it in front the inner eye with the signal flow in mind... :oops: :D
in Flexor it seems there are tools to 'construct' a signal then set/converted to be an envelope... but I can check it atm
Post by JoPo »
Yes ? Which ones ?
I'm impatient to have more info about logic & math on Sharc's BC modular & else : I don't find any module which filters increasing value or decreasing value.
-> Shark an entry needed at http://bcmodular.wikispaces.com/Home+Page !
w_ellis
Post by w_ellis »
I assume you've checked here too: http://cwmodular.org/html/env.html
Post by JoPo »
Yes I reviewed all the envelopes !
But ...
http://www.bcmodular.co.uk/forum/viewto ... 6c1f6fcd6f
I'm impatient !
Post by JoPo »
That's it ! Shark made it ! Exactly as I wished ! :o
Where else some kind of story like this would be possible to happen ? :P
http://www.bcmodular.co.uk/forum/viewto ... p=374#p374
:D
This will be awesome with BCM controls for extra precision.
Thanks JoPo and Sharc..
Dati
Post by Dati »
Hey I also searched for such Envs.
Where can I download these?
Its not working with the link for me, also when logged in on the BC Modular site.
Thanks Shark!
I will also look at your BC-Modular modules, they will be usefull for shure.
Ciao
Post by JoPo »
I think you must register at http://www.bcmodular.co.uk/forum to get download.
It's worth it !
