ModuleParameterList
soren_jepsen
ModuleParameterList
Post by soren_jepsen »
I'm getting my hands wet on SDK 5.1 while waiting for SDK6 to get somewhere. I have a problem thou. When I rightclick on a module in the project window, and select "Open ModuleParameterList" i get the error:
"Cannot read script file 'App@Scope@ModuleParameterList' "
Looking in the SDK/App folder, I find the "Scope" folder INSIDE the "Script" folder. However the error message seems to indicate that it should be directly in the "App" folder. I've tried to copy it out to the App folder, but it doesn't help.
Any ideas what is going on?
Thanks!
Soren
Re: ModuleParameterList
are you tunning sdk "as administrator"?
you should get a warning message asking if it's ok to allow sdk to make changes to your system and then you must answer "yes", if sdk is running in administrator mode...
fra77x
Post by fra77x »
You should download and install the 2 pathes you can find here: ftp://sonic-core.net/software/scope5/sdk5/
Scope-Pep.zip
protection patch.zip
Regards,
John
soren_jepsen
Thanks for the answers! Got the files and figured it out :-)
Cheers
Soren
sunmachine
Post by sunmachine »
The SDK 5.1 including those patches mentioned above aren't available anymore in the download area of the Sonic Core web site (at least I couldn't find them). So maybe someone could upload the patches here?
djmicron
Post by djmicron »
sunmachine wrote: Sat Jul 08, 2023 10:29 am The SDK 5.1 including those patches mentioned above aren't available anymore in the download area of the Sonic Core web site (at least I couldn't find them). So maybe someone could upload the patches here?
view protection patch.zip
(350.82 KiB) Downloaded 754 times
Scope-Pep.zip
(180.83 KiB) Downloaded 790 times
sunmachine
Thanks a lot, djmicron!
