glitches in winamp
scopus
glitches in winamp
Post by scopus »
hey theres this problem having for a while now just been ignoring but gets very annoying, when i play something in winamp every few seconds the audio glitches, tryed reinstalling winamp but still problem so thinking something with scope, ne ideas? thanks
guppy
Re: glitches in winamp
Post by guppy »
Do you have the same problem if you use foobar or something else ?
scopus
Post by scopus »
just tryed foobar yup same problem, but oddly found with windows media player no problem, but i cant stand that player,thoughts?
guppy
Post by guppy »
Foobar should be ok.
When you use a sequencer, do you have the same glitches ?
Then you should look to the basic scope parameters (bios).
scopus
Post by scopus »
no glitches in sequencer , just in the players winamp,foobar....except windows media player :-?
guppy
Post by guppy »
Do you use the standard wave source module ?
Is this only with mp3 or wav too ?
Do you listen to your music from an external drive ?
Did you try to change samplerates into foobar or scope ?
Foobar has a lot of options to configure for outpout, maybe you can look there. You can choose asio ouput instead of wave device.
http://www.foobar2000.org/components/view/foo_out_asio
scopus
Post by scopus »
ive got connected the mixer a "24 bit Wave Source 1" module
happens with both mp3 and wav
happens with everything- external, internal, main drive
im always working in 44.1, just tryed changing to different sample rate and not able get anything to play
should be able to get this to work again like before, everything was fine about about a year ago,
thanks
guppy
Post by guppy »
Here it works fine with "24bit wave source" and "wave source".
If you try wave source ?
scopus
Post by scopus »
yes wave source same thing, and just tryed reinstalling scope with no luck :(
thnks
bosone
Post by bosone »
are u on win7 64 bit??
i have the same (random) problem on wav playing throught windows but glitches are very rare
scopus
Post by scopus »
yup win7 64,
t_tangent
Post by t_tangent »
Try this. Create a second wave source module and connect that to another mixer channel. Then in Winamp or foobar etc open the configuration settings and select wave source 2, instead of wave source 1. Then try playing a file from winamp again and see if that glitches.
I had this happen a few years back, and doing this work around fixed the issue. The only reason I could think why this fixed the issue was possibly that it had something to do with the way windows handled the first wave source module buffers but then because the second wave module was created, the buffer for that was not locked into the windows audio system. I am sure that isn't exactly the way it is but the only way I can describe it. But it's worth a try so I hope it works. Cheers.
scopus
Post by scopus »
ah hoped that would work for me 2, but no luk again, dont understand why this not happining with windows media player though whats different there than the other players?
thnks
64bit?
the 64bit wave drivers have ocassional clicks. this is an old, known bug. new driver in v6....
t_tangent
Post by t_tangent »
Ah, shame it didn't work. Was an old fix on my win xp 32bit setup but worth a try I thought. Hope you get it sorted eventually.
scopus
Post by scopus »
thnks neways guys , hopefully will b ok in scope6, or perhaps need a reformat of windows
when the updated driver is released, it will probably work with v5 as well....
quantum
Post by quantum »
It sounds most likely a Windows issue, but if it's not:
Disable XTC. Try reclicking on the slowest ULLI latency option. Don't use anything other than sources, destinations, and mixer. Disable other audio drivers. In System Sounds select Creamware as default. Check the right IO Enabler selections. Reseat the card. Switch PCI slot if possible. Reinstall card driver. Disable harddrive cache writing.
And do all this:
http://forums.planetz.com/viewtopic.php?f=3&t=31345
If it's not that, then it's most likely a bad card, harddrive, processor, or motherboard.
Can't think of anything else...
