Interlace bug?
Roland Kuit
Interlace bug?
Post by Roland Kuit »
A strange thing is happening on my screen. Placing the Interlace module, it won't allow an other module directly on top of it. GUI problem?
http://www.rolandkuit.com/
petal
Re: Interlace bug?
Post by petal »
You have actually discovered a feature of the Scope GUI. If you look in the right upper corner of your device you'll see two icons. Below I have put a red circle around the icon of interest here:
The icon is a switch to control if a device should "always be on top" or "always lay below".
With the modular switched into "always be on top"-mode and the reverb device switched into "always lay below"-mode as pictured above, you will get the behavior you are referring to as a bug. I hope it makes sense :)
Re: Interlace bug?
Interlace.......Doesn't allow modules to sit underneath it as it has a larger shell that is not visible.
This is what i believe Roland is referring to.
It acts like 2 polarized magnets.... :cry:
Roland Kuit
Re: Interlace bug?
Thank you for your trouble Petal.
dawman wrote:Interlace.......Doesn't allow modules to sit underneath it as it has a larger shell that is not visible.
This is what I was referring too. But still don't understand. It acts if it is larger in a vertical way, but you see only half of it.
More important....it works!
Re: Interlace bug?
Here's a patch from the infamous RoyT showing the Interlace issue, and it's a great patch also for learning.
Sadly since the Cypriot Banking issue has caused Russians to kidnap Germans, we might not see him for a while. But I was thinking of starting a fund for his release.
Interlace Oscillator.png (276.41 KiB) Viewed 2702 times
Modular IV.rar
(577.29 KiB) Downloaded 248 times
