Nord Modular G1 and NMG2 Drum sounds
Preset lists and tools for Scope modules
Roland Kuit
Post by Roland Kuit »
Hi all,
I patched these and recorded them:
http://www.nordkeyboards.com/main.asp?t ... Perc/Drums
Wave-files for in a drum-sampler osc.
Feel free to use them in your productions.
They're noisy and filthy!
http://www.rolandkuit.com/
Re: Nord Modular G1 and NMG2 Drum sounds
Thank you so much kind sir.
I will use these in Modular Sample Oscillators nd Solaris.
DL'd the old school drums, amd the hammered strings...
Cheers :wink:
dawman wrote:Thank you so much kind sir.
Cheers :wink:
The oldschool drum samples are wav,- that works.
The hammered strings aren´t from Roland and are NORD sample format, they won´t work when renamed to WAV p.ex..
How will you use ´em ?
Did you find a way to convert for usage in sample playback devices other than Clavia Nord ?
ESC and ChickSysPro can change anything to wav. or raw.
Although I haven't tried it yet I am sifting through Vectron and jhulk's stuff for Solaris
right now.
But I will let you know if the option works.
dawman wrote:ESC and ChickSysPro can change anything to wav. or raw.
right now.
Thx Jimmy,- let me know ...
I´d be surprised when we can download the complete NORD sample library and use it otherwise ... :D
I have ESC and it doesn´t support .nsmp files for conversions.
But I don´t have Chickensys Pro though and maybe it´s an option,- but I doubt it is.
"The .nsmp sample format is a proprietary format. It is likely that the intent of Clavia is: that these samples only be used with Nord equipment."
http://www.norduserforum.com/nord-user- ... -t602.html
"The .nsmp is proprietary and encrypted. So it is not possible.
Unless you re-sample a Nord keyboard (hardware re-sampling) ."
http://www.motifator.com/index.php/foru ... ad/452162/
