i'm "Half-ASSio'd"...
Gary_101
Post by Gary_101 »
well, working with getting things happening with ASIO.
Seems fine in sending audio track output from Sequencers to SCOPE, using any of the 3 ASIO module types. (well, except Sonar... Cubase is fine and Reaper is fine too.)
But I can get absolutely no recording input to the audio tracks in the sequencers at all. I've got a drum machine hooked into PII's analog inputs, routed thru Ch 19, 20 in the STM 24/48. These 2 channels are routed to BUS 1/2, then into my ASIO2DEST64 module. This module has absolutely no connection whatsoever to any input of any sequencer I've tried (Cubase 5 LE, Sonar X1 LE, Reaper 64bit). The drum machine sound shows up fine in the Big Mixer, and I can hear it coming thru my external monitor fine. I've tried pumping the Analog input of PII directly into the ASIO DEST module, but zip - no sign of life on any of the input options in any sequencer.
Plus, now, Sonar won't even play back the wave files into Scope. "Unable to open audio playback device". In the device setup box in Sonar, it never seems to allow the full complement of Scope drivers, like now, I have 6 stereo pair (total 12) of each IN & OUT module; Sonar only lets me enable 4 of the 6 of each set. Driver settings are all set up at 16/44.1.
If anyone can offer any advice to an ASIO aspirant, it would be much appreciated.
thanks...
[ ps - for a "free" audio app, Reaper's 64 bit verion is looking kind of classy. Very fast. Nice GUI .. ]
Re: i'm "Half-ASSio'd"...
pm me.
