asio problems
karali
asio problems
Post by karali »
hi community,
i had pulsar1 and i wired with adat to yamaha 01v and worked just fine
now i aded pulsar2 card to my system and wired with stdm cable.
Now i have problem when i want to record mix i have noise pops in sound.i think is somthing with asio scope driver or pci slots ,if anyone have ide what shoud i change please help.
i try to make more latency , but not efect........................
HELP
JOVICA KARALI
Re: asio problems
well, start at the beginning....
the driver won't be affected by adding a card.
go to start\programs\accessories\system tools\system information\hardware resources\conflicts/sharing and tell me what, if anything is sharing an irq with a Scope card.
what os are you using?
karali
Re: asio problems
Post by karali »
windows xp profesional service pack 2
no match found in conflict/sharing and irq
JOVICA KARALI
Re: asio problems
really? none?
ok.
which is master and which is slave between O1V and Scope?
karali
Re: asio problems
Post by karali »
Master is pulsar , a16 is set on optical, and yamaha slave, and everything was same when i had just pulsar 1 and i didn't have cracks or pops.maybe i should rotate adat inputs-outputs on pulsar 1 or 2?
JOVICA KARALI
Re: asio problems
yeah, first clean the ADAT ports with compressed air.
then try swapping cables and ports. start with just one device, simplify the setup so that you can track down the source of the clicks.
karali
Re: asio problems
Post by karali »
garyb wrote:well, start at the beginning....
I/O Port 0x00000000-0x00000CF7 PCI bus
I/O Port 0x00000000-0x00000CF7 Direct memory access controller
IRQ 23 Intel(R) N10/ICH7 Family USB Universal Host Controller - 27C8
IRQ 23 Intel(R) N10/ICH7 Family USB2 Enhanced Host Controller - 27CC
IRQ 16 Intel(R) G41 Express Chipset
IRQ 16 Microsoft UAA Bus Driver for High Definition Audio
IRQ 16 Intel(R) N10/ICH7 Family PCI Express Root Port - 27D0
IRQ 16 Intel(R) N10/ICH7 Family USB Universal Host Controller - 27CB
IRQ 16 Creamware Pulsar2
IRQ 17 Intel(R) N10/ICH7 Family PCI Express Root Port - 27D2
IRQ 17 Atheros AR8132 PCI-E Fast Ethernet Controller
IRQ 17 Creamware Pulsar
IRQ 18 Intel(R) N10/ICH7 Family PCI Express Root Port - 27D4
IRQ 18 Intel(R) N10/ICH7 Family USB Universal Host Controller - 27CA
IRQ 19 Intel(R) N10/ICH7 Family USB Universal Host Controller - 27C9
IRQ 19 Intel(R) N10/ICH7 Family Serial ATA Storage Controller - 27C0
Memory Address 0xA0000-0xBFFFF PCI bus
Memory Address 0xA0000-0xBFFFF Intel(R) G41 Express Chipset
JOVICA KARALI
petal
Re: asio problems
Post by petal »
karali wrote: IRQ 17 Intel(R) N10/ICH7 Family PCI Express Root Port - 27D2
Your creamware card should be on it's own IRQ, not sharing it with anything else.
You could try to move it/them to a different PCI slot or if I remember correctly, in Windows XP you can assign IRQ's and possibly solve the problem that way, but I don't recall how.
Re: asio problems
you can move the Scope card, or move or remove the add-on ethernet card.
karali
Re: asio problems
Post by karali »
i unable everithing and now irq 16 is sharing between creamware pulsar 2 and intel g 41 graphic card.does somebody know how to change irq on graphic card, if it is posible?
JOVICA KARALI
Re: asio problems
there's no way to change this other than changing the slot the Scope card is in. that stuff is hardwired in the motherboard.
Eanna
Re: asio problems
Post by Eanna »
Afaik, some motherboard bios software does allow you to reassign irq numbers.. Check your bios manufacturer manual.
Re: asio problems
windows acpi does not allow it even it the motherboard's bios does, afaik....
Re: asio problems
garyb wrote:windows acpi does not allow it even it the motherboard's bios does, afaik....
Correct !
Any IRQ higher than 15 is a virtual IRQ anyway.
Sometimes it´s best to start from very beginning.
Have computer w/ graphics card, driver and OS incl. chipset drivers installed ,- than insert SCOPE PCI card, install SCOPE and see if it has an exclusive IRQ,- if not, disable USB controllers,- if not, swap the card until it works.
Don´t add any other card before.
I have the same problem w/ a old machine and SCOPE 4.5 and PCI card,- just only because I want to have a Adaptec SCSI PCI card, USB/Firewire combo card (TI chipset) and Realtek network card in addition.
Regardless what I do,- DPC latency checker reports the yellow and red spikes.
Seems it´s not possible to use all the slots on a mobo, depending on brand/model,- so be happy it works w/ SCOPE PCI alone.
