Check -> SM lga 2011 socket MB with native 3 PCI here...
endre70
Post by endre70 »
Hi all
It's that time again. Need more power and are seriously considering the following:
http://www.supermicro.nl/products/mothe ... srh-7f.cfm
Is there any reason why this shouldnt work with my 2 x scope cards?
And which CPU is recommended? and why?
http://en.wikipedia.org/wiki/LGA_2011
Other things to consider? Thoughts in general?
Hopefully the E-Ivy Bridge for 2011 socket will come soon. 2de quarter of 2013 I hear... And from my understanding the most valuable feature would be: "Ivy Bridge will dynamically allocate resources to threads so that if there is only a single thread active, all resources will be dedicated to that thread rather than some going unused as with SB's static allocation." - ( as hypertreading is a no option for us Scope users.) Taken from http://www.techspot.com/guides/502-intel-ivy-bridge/
Thank you!
Re: Check -> SM lga 2011 socket MB with native 3 PCI here...
that might work well, no one has tried it to my knowledge.
in general Supermicro is top notch. i can tell you that the 1366 XEON would definitely work.
endre70
Post by endre70 »
Cool Garyb!
Yes. I also considered this 1366 board: X8DA3 - http://www.supermicro.nl/products/mothe ... /x8da3.cfm
and this 1155 board: X9SCA - http://www.supermicro.nl/products/mothe ... /x9sca.cfm
both with native PCI support.
But the 2011 board have more future options..
so far, the 1155 boards have all been a big disappointment.
i've used a version of the x8D board and i can tell you that it's the bomb.
endre70
Post by endre70 »
garyb wrote:so far, the 1155 boards have all been a big disappointment. .
Yes I've read that. I thought it was due to the lack of native PCI..anywho.. I wont go near it...
garyb wrote: i've used a version of the x8D board and i can tell you that it's the bomb.
As for the x8D board...hmmm tested and working.... you make it difficult garyb..
