I have a strange problem in SFP: the fx insert buttons on all mixers don't react at all.
This is for some time already, and I got used to work around it by putting the insert effects in the project window.
Which is annoying, so I wanne get rid of this strange behaviour.
Should there be an insert mainmenu folder in SFP?
Yet it's not that the effects aren't found, the buttons don't do anything!
And I don't have a clue where to start to repair this.
I removed all old installs and backups from the computer, removed all files in the extensions folder and the Preferences folder, made a new install with newly installed drivers.
No succes.
The mac with the cards runs on OS9.2.2, and the system is reinstalled a while ago.
I had the inserts problem already befor that, so I hope you guys have a trick.
I don't think it's mac related, as SFP runs kinda in it's own environment or shell, at least it does look so with that own menu strip.
Insert fx buttons SFP don't work - Solved!
Re: Insert fx buttons SFP don't work
for auxs or for channels?
i really don't recommend using inserts on an aux. i haven't heard of a problem on the channels...
inserts for channels or master channels.garyb wrote:for auxs or for channels?
I can't load a Optimaster in Master Mix out, or any insert fx in any channel slot.
Weird eh?
Normally you double-click on an insert 'slot' (graphically, in the 24/48 mixer), and you'd expect a list or browswer, but nothing happens.
yeah, that's weird.
i'd rerun the installer. there's something corrupt. pep file maybe?
rebuilding the project does nothing right?
no, I deleted all content from the installer startup window, and took the 24/48 with 1 time Adat connected, nothing.
The same for all other mixers.
Could it have something to do with XTC?
I never used it tho.
thanks for your interest
zzzzzzzz now...
zzzzzzzz now...
oh btw, what am I supposed to fill in at the Settings/Directories/Modules?
Devices? Applications? Bin?
Have no clue about pep files tho?
What's pep files?
If you could give a hint, everything is welcom
What's pep files?
deleted all devices from the installer window?
pep files are nothing for you to mess with. it's possible that a file connected with the gui has become corrupt, that why i recommended rerunning the installer.
you shouldn't need to do anything with those addresses. a computer is a big file cabinet. if the files are in tact and in place, it MUST work.
by the way, on a pc, you right click to use an insert. are you sure you don't cntrl click or something like that?
For some reason I overlooked the cntrl key, as I was overly focussed on double clicking...garyb wrote: this put me on the right path:
quote: by the way, on a pc, you right click to use an insert. are you sure you don't cntrl click or something like that?
Feel ashamed
Slow progression of loss of problem solving capabilities not seeing the obvious?
Anyway, the only problem I had in my partly renewed 2mac setup has solved.
thanks gary
