Windows8 system sound [resolved]
babaorum
Post by babaorum »
hello,
ASIO works fine with win8 but now I don't have windows's sounds ...
The System (when I want to test sound) say to me that scope is opened in another application ... :(
Sonic Core Luna II + Pulsar II scope v5.1.2709-x64, Cubase 9.0.20 (64), Pro Tools 12.7, Wavelab element 9 (64), windows 8.1 pro (64), Asus P6T 18Go RAM core i7 920, SSL Duende Native - Lexicon PCM Reverb Bundle - Waves - Sonnox
Re: Windows8 system sound
it will work if you have selected the proper pair of wave drivers in windows sound properties. it will be Scope speakers 1 or 2, depending on your machine. then you will need to have the proper wave modules connected in the routing window.....
there isn't anything else involved...
babaorum
Post by babaorum »
Thanks Gary but I just found the solution.
In sound manager of windows I have changed the parameters in : properties/advanced statistics/ I must adjust 16bits 48000 Hz by default in 'Format by default' selection and in 'exclusive mode' I unchecked the box 'Authorize applications to take exclusif control of this device'.
