Does Adern's Flexor only work up to scope v4.0?
I've tried to import it into v5.1 but it keeps asking for key even though I've done it.
Flexor on v5.1
Music Manic
Re: Flexor on v5.1
have you got the version 5 key for it
Music Manic
Re: Flexor on v5.1
Yes I have v5.0. Is it still ok with 5.1.jhulk wrote:have you got the version 5 key for it
Music Manic
Re: Flexor on v5.1
I keep getting:
Registration of ODXFLX2 pop up!
Re: Flexor on v5.1
its not loaded in the correct location
its looking for the dsp files
and cant find it
did you use the exe to install the flexor 3
and cant find it
Music Manic
Re: Flexor on v5.1
Yes I just re-installed it but I directed it to my Scope folder and it placed everything in Modular2Modules/Flexor, but still the same error.jhulk wrote:its not loaded in the correct location
and cant find it
Music Manic
Re: Flexor on v5.1
You were right jhulk.
They needed to moved into the Devices/Modular2 folder.
Thanks for your help.
Music Manic
Re: Flexor on v5.1
Bump
Reinstalled on Windows 7 Scope 5.1 and some device load but some keep asking for the key.
Does anyone have it working fully on 5.1?
I have loaded the devices int the correct modular 2 devices path
Could it be administration problem?
Music Manic
Re: Flexor on v5.1
Ok I had it working but I had app@dialog problem then I re-installed and have same problem. Does it have to be on root C: DRIVE?
My root drive is J:
Some modules load without registration nag then some do. Weird!!
My root drive is J:
Music Manic
Re: Flexor on v5.1
What is the ODXFLX2 File?
