Unregistered Device
MrV
Unregistered Device
Post by MrV »
Hi ,I'm a bit puzzled by an error message .
I recently put together a new PC system based around my old setup Scope 4.5 , 3 PwrPulsars 45 dsp .
Part of my set up was the STW Plate and STW A-100 ...these devices are in my registry and as listed
in the rgy file ,and so on .
However , loading a recent project including STW Plate ...I'm getting "Problem: Unregistered Device"
mentioning the STW ,even though it's there in the project , wired up correctly and can be edited etc ...
What would cause this ?
Thanks , Michael
YISH313z
Re: Unregistered Device
Post by YISH313z »
Make sure that you dont have a duplicate anywhere from a previous install, I learned the hard way, I kept getting Masterverb not registered errors because of this, not realizing that Scope was looking in the previous location for the dev.
just my 2 cent
like if you had a v4 folder AND a v5.1 folder?
yes, that would do it...
MrV
Post by MrV »
Thanks chaps , I just realised what happened ... I'd used the larger rgy file of 2 I have , assuming it had all my devices ...
it doesn't ...it covers a range of cards I've had ... the smaller rgy file is actually the correct one and fixed it .
Up there for dancing :)
Cheers , M
