hi! could you please tell me which synths are included with the luna 2?
i'd like to answer me the same question about pulsar 2...thanks!
luna 2 and pulsar 2 included synths??
- garyb
- Moderator
Re: luna 2 and pulsar 2 included synths??
not much, if it's v4 or before, between eight and fifteen basic ones depending(or so)...the Pulsar2 may or may not have a synth and sampler pack, which would add quite a few.
almost everything with v5.1...
- dante
Theres a table here under 'Scope Setup and Synths' that shows what synths you get depending on Scope version ....
http://www.hitfoundry.com/issue_09/syn_mast.htm
musictech
dante wrote:Theres a table here under 'Scope Setup and Synths' that shows what synths you get depending on Scope version ....
this ''table'' doesn't says anything about cards and included synths.i mean that for example,powerpulsar with 15 dsps icludes all the synths and samplers synths.i know that the number of the synths depends on card version...
- dante
Judging by the 2 versions of Scope upgrade in the S|C shop, the 3/4DSP upgrade is cheaper than the big card upgrade yet you still get the same synths as the big cards (as shown in the chart - with the exception of ProTone - which could be wrong).
Maybe the 15DSP rule was more a Creamware thing & since S|C the rules are more about what version of Scope you have rather than the size of the card.
If someone can clarify I'll update the table.
- garyb
- Moderator
it depends on when the card was sold, as to what it has included. S&S packs are not an absolute given for 15dsp cards, but they are more than likely. for 6 dsp cards a S&S pack is maybe 40-50% likely. for a 3 dsp card, much less likely. there is no absolute answer. cards have what they have.
