Does Noah Ex come with keyfiles in the box? Should I buy it?
Discuss the Creamware Noah
Sparky55
Post by Sparky55 »
Sorry for the noob questions. I have an opportunity to acquire a new-in-unopened-box Noah Ex and want to be sure I will have the necessary keyfiles to install/activate all the available instruments and the software. Does everything come in the box or will I need to obtain keyfiles from S/C? ANd is that a difficult proposition? Or do you all recommend that I dismiss the idea of purchasing a Noah?
I'm a hardware guy, own a B4 and Minimax, and would like to have access to the Prodyssey and Pro12. The Noah Ex seems like the way to go provided I keep the original software and firmware. Or am I misunderstanding the issues with the firmware upgrade and software compatibility? I never worked with keyfiles, either.
I will be operating the software under WIndows XP and using the Noah live via midi. Thanks for any advice.
Mark
Re: Does Noah Ex come with keyfiles in the box? Should I buy
you only need the keyfiles when you update the firmware.
S|C can send you a keyfile if you request it. i would request it, just as a safety.
