micromixer x - modular
djmicron
Post by djmicron »
This one is a test before adapting the bigger ones.
When channels are in mono mode, only left input is active.
micromixer.zip
(282.42 KiB) Downloaded 287 times
Re: micromixer x - modular
Post by jksuperstar »
Wow, now THIS is VERY useful ;) My thanks for your willingness to do this. I imagine the possibilities will only be better with Open SCOPE 6 (as S|C hints one would be able to incorporate an extra LFO into a MiniMAX for example, or make a new GUI for it).
This is very cool, thanks, DJM!
I always liked Modular Shell Mixers.
Hopefully this is just a start, and the STM1632X or a mixer with at least 2 AUXs would be added later.
I'd love a Project window full of Modular Shells where little room is used.
THen have Screensets for each combination of devices and Modular shells to be viewed.
Thanks Again DJM..
faxinadu
Post by faxinadu »
yeaaaaaaah! does this require scope5/mod4?
http://www.oceanswift.net
Music
djmicron
Post by djmicron »
it works in any modular version, but it requires scope 5 due to different serials between v5 and v4 devices.
If you have scope 4, drop me a message
djmicron wrote:it works in any modular version, but it requires scope 5 due to different serials between v5 and v4 devices.
Scope 5.1 and 4.0 here,- on different machines ...
Does that mean there´s a solution for both the versions ???
That would be amazing.
O.T.:
I have a Scope 4.5 installer too and wonder if there were Scope 4.5 keys needed or if Scope 4.5 works w/ v4.0 keys ?
djmicron
Post by djmicron »
v 4 and v4.5 should be the same keys(if i remember right).
I can pack the device on sdk 4 with the old version of the devices, then it will run on v 4.
djmicron wrote:v 4 and v4.5 should be the same keys(if i remember right).
Cool, thx !
Minimax possible too ? :-)
I don´t have B2003 and Profit 5 for v4.x, - but Minimax (+ Prodyssey and 4 ZARG synths).
The idea is, running Modular III (and occasionally STS sampler) only on the Scope v4.x / 15DSP PCI card machine, connected by ADAT I/O and MIDI to XITE-1.
I expect it helps running devices not being optimized for XITE like STS samplers and/or running more devices when XITE is at it´s DSP load and SAT connection limits.
Just a workaround until Scope 6 (or higher versions) will be released ...
djmicron
Post by djmicron »
i miss the prodissey, but most of the rest is possible, including minimax.
Cool, thx !
