hi,
just embedded the minimax into modular module.
Just drag it into your modular shell and connect from left to right:
midi in, audio in, audio out L/R, midi out.
The button on the top left is to open/close the minimax surface.
CC83 is reserved for opening the surface.
Scope v5 serial needed.
p.s. since the module is protected and there is not polyphony control on its surface, i have added polyphonic modules, 3. 6. 9 and 12 voices.
minimax modular adapter
- minimaxmod_poly.zip
- (3.06 MiB) Downloaded 455 times
- minimaxmod.zip
- (626.01 KiB) Downloaded 457 times
- minimaxmod.jpg (27.93 KiB) Viewed 7181 times
Re: minimax modular adapter
I was right there when this popped up.
Just curious though, is it Polyphonic...?
I can;t seem to find the option, and I tried using the Portamento and Unison Detune on the Mod IV MVC C, and couldn't get more than Monophonic regardless of the 12 voices MVC was showing.....
It's really nice though as is, as I enjoyother effects than the built in ones.
Grazzi
Grazzi
WOW! Thanks
This looks very interesting indeed. Maybe I'm just a modular noob, but what do you gain by having the minimax inside modular like this new module now makes possible? How is this different from just routing the signal from a Minimax outside modular into modular and then manipulate it in there?
Cheers,
Thomas
Cheers,
Thomas
the difference is that you can save the modular patch independently from the scope project, so you can have a chain of synthesizers inside one modular patch and this will make more sense when i'll upload other synthesizers adapted for modular.
Check - I get the picture now
Yes one little Shell with everything you need in it, including your favorite Delay or Phaser since most are chorus, and less tweakable delays.
My choice of Delays recently changed to the Ducking Delay because it keeps the sound up front and full then the delay kicks in like a Reverb tail....
Anyways, I now have a tab named DJMicron, as I expect more great ideas coming our way.
Thanks So Much,
Thanks So Much,
tip for xtc modepetal wrote:This looks very interesting indeed. Maybe I'm just a modular noob, but what do you gain by having the minimax inside modular like this new module now makes possible? How is this different from just routing the signal from a Minimax outside modular into modular and then manipulate it in there?
Cheers,
Thomas
once u create a modular pach with the synth in it and assign all cc to the noobs and save the modular the cc will be recalled in xtc mode oderwihse u need to save the cc definitions and reload on each project load for normal synth's ....
lg widy
awesome idea for module micron! this is def gonna come in handy
cheers
cheers
