I've recently got XTC mode working, and primarily at the moment I'm using the card as a sound source in Reaper, having an instance of STS2000P loaded for the tracks that I want to use SoundFonts or sample sets from the Powersampler AKAI disk I had included with my 3DSP card.
I'm having a problem with the third instance of the 2000P where it is behind (time-wise) the rest (I have 5 instances running before I ran out of DSP
Is this something that anyone is aware of, and has a possible remedy? I did remove and replace that instance of the STS2000P, but to no effect.
I haven't done anything special in terms of setting latency for that particular channel. The PDC for all of the channels coming from the 3DSP card is 1536, and in the plugin/FX window for each of those channels, the STS2000P instances show "1154/1536 spls" in the bottom left.
Any help would be greatly appreciated!
Thanks in advance for your help,
unaHm
PS: I have a couple of other cards on their way, so I'm looking forward to making some large XTC-based projects! The integration with Reaper and Renoise is fantastic - I'm very pleased! I was trying to do EXACTLY THIS with a SoundBlaster Audigy 2ZS and the DSP-Programmable kXProject drivers, but it never really worked. Plus, I make use of SoundFonts and samples, and the VSTi plugins I've been using weren't happy running more than a couple of instances.
