LP filter control
soren_jepsen
LP filter control
Post by soren_jepsen »
I'm messing around in Modular2 (waiting impatiently for my XITE-1), and I'm having a bit of a problem controlling a LP filter. I've attached a pic demonstrating the setup. I want the filter to follow the frequency of the notes. In this setup it won't when you sweep the keyboard, since the MVC is set to Gliss. It will just keep the freq untill you lift the finger. Is there a way to do this, without changing away from gliss?
Regards
Soren
LP filter.jpg (65.23 KiB) Viewed 3142 times
djmicron
Re: LP filter control
Post by djmicron »
it's because the mvc sends the changes on the freq out.
Have you tried to connect the freq out to the cutoff modulation input?
It just needs to be multiplied.
I have attached the patch.
note2filter.zip
(389.22 KiB) Downloaded 215 times
petal
Post by petal »
Have you tried to raise the voice count to 2 or more?
Just dl'd it as I was surprised to see a Noise Oscillator, so I will have some fun.
Ankyu...
soren_jepsen
Hmmm. It works with the multiplier into CFm1, but using Keyf from the Note output (and raising the number of voices to avoid note stealing) gives a wider range of frequency control.
**********EDIT*********
eeehm, raising the number of voices means leaving monophonic mode, which defeats portamento somewhat.
Is there a way to keep the level of frequency control you get from the "note to Keyf" method, but still maintaining "true" portamento? By true, I mean like the sweep you get when holding one note down in monophonic portamento, and hitting other notes. The note keeps gliding back to the note you keep holding.
....am I making sense?
Regards
Soren
djmicron
Post by djmicron »
with the standard mvc you can't .
With the mvc c provided with modular 4, there is the legato and the retrigger option, but there is not portamento using notes.
For portamento you have to work with the frequency out.
You only have to adjust the freq multiplier to a value that fits your needs.
Else you can follow a different approach, using envelopes to control the filter modulation.
I'll make a patch later.
soren_jepsen
Specific and to the point. A great answer :-)
Soren
