Scope V5.1 not loading into task bar at start up
krizrox
Post by krizrox »
Curious problem. I just installed the latest Scope software update V5.1 and I noticed that Scope no longer starts up along with the other start up programs when I boot up (or reboot). I have to click on the desktop icon in order to get it to load up (then the icon appears in the task bar area). I tried reinstalling from scratch and it still doesn't work. Aside from that the program works as expected. Any ideas?
Using Win XP Pro (32 bit).
Also don't see it in the msconfig start up sequence.
Re: Scope V5.1 not loading into task bar at start up
Post your cset.ini - the issue may be there.
krizrox
Post by krizrox »
This is a printout of the V5.1 cset.ini file. I did a little investigating on my own. I compared it to the V5.0 cset.ini file from the backup archive I made prior to installing 5.1 and the only thing I can see that is different or unique about this V5.1 ini file is a reference under the heading called [Runpep] DontRestart=0.
I see no such entry in the V5.0 ini file. I might remove that entry and see if it makes a difference.
[hw]
intBlkSize=128
SelectDriver=1
[SC Scope]
Build=v5.1.2709-x86
[Runpep]
DontRestart=0
InScreen=1
Language=english
[FileBrowser]
All Files=0
STS-Samples=0
LastPath=H:/Program Files/SCOPE PCI/Devices
[AudioFormats]
Wav=Wav
[Installer]
Version=5.0
App=SCOPE PCI
OS=5.0.2201
ProductID=1
[ReferenceResolver]
All files_Paths=H:\Program Files\SCOPE PCI/;
Modules/Devices_Paths=H:\Program Files\SCOPE PCI/Devices/;
Presets_Paths=H:\Program Files\SCOPE PCI/Presets/;
All files_AutoUse=1
Modules/Devices_AutoUse=1
Presets_AutoUse=1
[StaticPath]
Modules=
Modular=H:\Program Files\SCOPE PCI/Modular Modules/
Projects=H:\Program Files\SCOPE PCI/Projects/Examples/
Effects=H:\Program Files\SCOPE PCI/Devices/Effects/
Presets=H:\Program Files\SCOPE PCI/Presets/
HardwareIOs=H:\Program Files\SCOPE PCI/App/Application/IOs/Hardware/
SoftwareIOs=H:\Program Files\SCOPE PCI/App/Application/IOs/Software/
Bitmaps=H:\Program Files\SCOPE PCI/MRC Skins/
Devices=H:\Program Files\SCOPE PCI/Devices/
Samples=H:\Program Files\SCOPE PCI/Samples/
[Path]
Projects=H:\Program Files\SCOPE PCI\Projects\Examples
[APPEARANCE]
ToolTips=1
DragWindows=1
StandardCursor=1
GridY=6
GridX=6
[LOAD]
AlignSurfaces=1
LoadMixer=STM 1632.dev
LoadMixerEnabled=1
LoadDefBoard=0
[AUTOCONNECT]
InstrumentToMixer=0
EffectToMixer=0
AudioSrcToMixer=0
DeviceToMidiSrc=0
[SEQPATH]
Path1=
[ASIO]
XTCMode=0
application=H:\Program Files\SCOPE PCI/App/XTCApp/XTC.pro
Pluginwrapper1=H:\Program Files\SCOPE PCI/App/XTCApp/vstsynthplugin.mdl
Pluginwrapper2=H:\Program Files\SCOPE PCI/App/XTCApp/vstplugin.mdl
Pluginwrapper3=H:\Program Files\SCOPE PCI/App/XTCApp/vstplugin.mdl
Pluginwrapper4=H:\Program Files\SCOPE PCI/App/XTCApp/vsthostplugin.mdl
[XTC-Config]
AddHost=1
SelectDriver=1
intBlkSize=256
[Host]
Scoperev=128
[Host-Config]
Numboards=1
Board0=Host
[SFP]
Favourites_Minimized=0
Favourites_Size=102
FileBrowser_Minimized=0
FileBrowser_Size=435
ReferenceResolverOptions_SizeY=300
ReferenceResolverOptions_SizeX=332
ReferenceResolverOptions_PosY=106
ReferenceResolverOptions_PosX=315
ReferenceResolverOptions_Show=0
Dsp Load_SizeY=106
Dsp Load_SizeX=194
Top_Minimized=0
Top_Size=477
About_Show=0
About_PosX=254
About_PosY=14
ControlRanger_Show=0
ControlRanger_PosX=289
ControlRanger_PosY=89
ControlRanger_TopLevel=2000
SFPBar_PosX=1130
SFPBar_PosY=643
SFPBar_SizeX=238
SFPBar_SizeY=207
SFPBar_TopLevel=100000
SFPBar_RestoredSizeY=582
Bottom_Size=88
Bottom_Minimized=1
DSPLoad_Load=0
Dsp Load_Show=0
Dsp Load_PosX=282
Dsp Load_PosY=82
Dsp Load_TopLevel=2000
Registry_Load=0
ModuleRegistry_Show=0
ModuleRegistry_PosX=300
ModuleRegistry_PosY=102
ModuleRegistry_TopLevel=2000
Options_Load=0
Options_Show=0
Options_PosX=296
Options_PosY=96
Options_TopLevel=2000
Resolver_Load=0
ReferenceResolveOptions_Show=0
ReferenceResolveOptions_PosX=302
ReferenceResolveOptions_PosY=104
ReferenceResolveOptions_SizeX=332
ReferenceResolveOptions_SizeY=250
SFPRouting_Show=0
SFPRouting_PosX=253
SFPRouting_PosY=4
SFPRouting_SizeX=790
SFPRouting_SizeY=519
SFPRouting_TopLevel=0
FileBrowser_Show=0
FileBrowser_PosX=479
FileBrowser_PosY=86
FileBrowser_SizeX=241
FileBrowser_SizeY=518
FileBrowser_TopLevel=1
Splitter_Size=0
Splitter_Minimized=1
SFPDesktop_PosX=2
SFPDesktop_PosY=4
SFPDesktop_SizeX=1092
SFPDesktop_SizeY=624
SFPDesktop_Maximize=0
PulsarConfigSurface_Show=0
PulsarConfigSurface_PosX=274
PulsarConfigSurface_PosY=75
PulsarConfigSurface_TopLevel=2000
[RecentFileList]
Entry5=
Entry4=
Entry3=
Entry2=
Entry1=H:/Program Files/SCOPE PCI/Projects/Examples/default.pro
Entry0=h:/program files/scope pci/app/ScopeApp/StartProject.pro
Yep I was not sure the exact key in the cset.ini but from here:
http://forums.planetz.com/viewtopic.php?f=1&t=20951
astroman wrote:to prevent Scope from auto-starting
edit the file cset.ini in the sfp\app\bin directory
change the entry DontRestart=0 (which means start automatically)
to DontRestart=1
You could also try putting Scope shortcut in the machines autostart folder. Something like :
"C:\Program Files\SCOPE PCI\App\bin\Scope.exe" -s
The '-s' makes it start minimized according to :
http://forums.planetz.com/viewtopic.php?f=3&t=30841
And a registry Hack here:
http://forums.planetz.com/viewtopic.php?f=1&t=18155
krizrox
Post by krizrox »
thanks dante - adding the -s did not solve the problem.
I uninstalled V5.1 and reinstalled V5.0 and it works correctly (without the -s in fact).
There is something wrong with the latest version 5.1 software in this regard. I will notify SonicCore and hopefully they can fix the problem in the next update. For now I will stay with V5.0. Or maybe I'll just ask for my money back. :P
i wrote you a response to your email to support.
it's a pretty simple fix. just drop a shortcut to Scope.exe into the windows startup folder.
krizrox
Post by krizrox »
got your email thanks Gary. :)
sure, let me know if you have a problem or need more specific instructions...
krizrox
Post by krizrox »
frankly, it was a dumb thing to complain about. it's the same number of mouse clicks to open a project ha ha
