5.0 VS 5.1
YISH313z
5.0 VS 5.1
Post by YISH313z »
I've posted my unflinching trouble with the STS sampler under Scope 5.1 were I could not get more than 32 voices for the STS 5000, or load more than one STS-3000 at 32 voices despite being able to load 6 STS-3000 on Scope 4.0. (Async Error)
So, digging into the back of my mind I remembered seeing the key for 5.0 when I installed 5.1.
What are the differences between these two? (Keep in mind I'm on Windows XP SP3.)
The reason I ask is because I decided to install 5.0 and see if the STS woes existed there as well, and lo and behold...they don't, so far. :D
Id hate to get deep into using 5.0 only to bump into other issues not foreseen.
Any insight ?
Re: 5.0 VS 5.1
5.1 was released primarily for Win7 64bit drivers. Don't know for sure if there were any other upgrades or bug fixes.
YISH313z
Re: 5.0 VS 5.1
Post by YISH313z »
So I shouldn't expect any Gotchas using 5.0?
Re: 5.0 VS 5.1
go ahead and use v5.0.
YISH313z
Re: 5.0 VS 5.1
Post by YISH313z »
10-4
Re: 5.0 VS 5.1
I've been using 5.0 since it came out and haven't had really any issues with it. I just recently loaded up all of my old Akai sample disks to the hard drive for the STS. Works like a champ. Then again I haven't really tasked it heavily. I usually just record a midi track to audio and then disable it, then go back and re-record it if I need to make any changes. I understand for automation and such someone would need to run several midi parts at the same time though.
YISH313z
Re: 5.0 VS 5.1
Post by YISH313z »
Any issues using 5.0 with a dual core acpi pc profile?
